Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Home
Search
Recent Posts
Gallery
Search
Stats
Login
Register
This topic
This board
Entire forum
Google
March 18, 2025, 10:48:04 PM
Technical Information
General Tech
LT1/T56 help
Add to Reputation:
What do you think of this post?
I agree
I disagree
Comment:
« previous
next »
Print
Pages:
1
2
Author
Topic: LT1/T56 help (Read 4172 times)
v8_7ryan
In The Bleach Box
View Gallery
Re: LT1/T56 help
Reply #15 on:
February 21, 2012, 06:54:36 PM »
Im working on getting a maf... Would any gm maf work? I now have the car running on all 8 cylinders, so would not havinv the maf hookd up make it run super lean?
Logged
gadzooks
Supporting Member
Launching!
Got Torque?
View Gallery
Re: LT1/T56 help
Reply #16 on:
February 22, 2012, 08:26:43 PM »
you want the proper one for the engine, not having a MAF will cause the car to run lean and fall on its face anytime you touch the gas
Logged
1987 Base/Light Weight with '95 Firebird LT1/T5
Danrx5.7
Guest
Re: LT1/T56 help
Reply #17 on:
February 27, 2012, 04:51:21 PM »
My fc was doing the same thing when I first started it, and it was the fuel lines the return line was clogged, then I unclogged it, and the fuel pump didnt give me the enough pressure, so I bought a new one and the problem ended
Logged
v8_7ryan
In The Bleach Box
View Gallery
Re: LT1/T56 help
Reply #18 on:
February 29, 2012, 07:16:41 PM »
I know this isn't the right section to be posting this but my alternator is not charging and I was wondering If I had it hooked up right. I have a 12 volt power from the Battery, and 2 brown wires pluged in from the harnes is there anything I am missing I'm confused?
Logged
v8_7ryan
In The Bleach Box
View Gallery
Re: LT1/T56 help
Reply #19 on:
February 29, 2012, 07:17:57 PM »
I have a brand new walbro 255 it should work and fuel lines are also new along with fuel filter
Logged
v8_7ryan
In The Bleach Box
View Gallery
Re: LT1/T56 help
Reply #20 on:
March 05, 2012, 09:20:09 AM »
Maf is hooked up now and it ran all the way up redline, would a rip in the intake elbow coupling make a idle high?
Logged
digitalsolo
Administrator
Top Fuel
View Gallery
Re: LT1/T56 help
Reply #21 on:
March 05, 2012, 09:37:14 AM »
Negative. If it is after the MAF it could mess with fueling.
Logged
1988 Mazda RX7 - Turbo LS1/T56/ProEFI/8.8/Not Slow... sold.
Chuck78
In The Bleach Box
View Gallery
Re: LT1/T56 help
Reply #22 on:
March 05, 2012, 11:15:50 AM »
What kind of throttle body is on it? Stock or aftermarket?. Has someone adjusted the closed throttle stop screw? Possibly to the point that the IAC is being bypassed? I have had issues with an aftermarket 58mm t-body bypassing the LT1's idle air circuit inside the intake manifold and causing an erratic idle. Also, make sure there are no vacuum leaks (even between the MAF and T-body).
Logged
Print
Pages:
1
2
« previous
next »
General Tech
LT1/T56 help
Jump to:
=> General Tech
