March 17, 2025, 11:07:53 PM
Author Topic: FC manual rack to P/S with Toyota MR2 electric Power Steering pump .  (Read 27518 times)
Offline RXTC
Re: FC manual rack to P/S with Toyota MR2 electric Power Steering pump .
« Reply #45 on: February 08, 2012, 09:38:48 PM »
Whats the pump rated at? 30A?
Offline mpcv2000
« Reply #46 on: February 09, 2012, 06:12:20 AM »
I don't know.
Martin !
Offline mpcv2000
« Reply #47 on: February 13, 2012, 08:14:49 PM »
Updating this project.
Routing of the pressure and return lines are under the pan right on top of the Granny's cross member , drilled 2 holes and attached 2 clamps on it.
This is the relay I bought to activate the pump and I've installed a 40 amp fuse between the relay and the battery.
I'm not sure about the size of the fuse I should use to protect the pump but I will update the thread when I will know.
Soldered connections and shrinked .
I'm not using ( yet ) the Toyota electronic module to control the pump ( VSS , etc. ) , I'm triggering the pump with the fog light switch (I don't have fogs and the switch is there doing nothing) so on long HWY trips , I'll be able to shut the pump off  or stuck in trafic etc.
No test drive yet since we are in Feb. and my car won't go out before April 1st if weather permited.
New updates later springs 2012 .
 :cheers:
Martin !
Offline mpcv2000
« Reply #48 on: March 19, 2012, 10:23:21 PM »
Very happy how this project turned out.
I've been driving the car for 2 days and it is more then perfect.
Very nice to have a power steering and a fresh rebuilted differential .
The car feels very different .
I love it so far. :cheers:
Martin !
« Reply #49 on: March 20, 2012, 12:48:23 AM »
Awesome, glad to hear it.  :)
Offline Chuck78
« Reply #50 on: March 21, 2012, 11:37:13 AM »
Glad this worked out so good.  Your install is sooooo clean!  Definately something to consider.
