bought this in september as a fun toy to cruise on the weekends with, fixed some minor problems it had such as the radiator (turned out to be thermostat and wiring) and wheel hop (solved with samberg rear diff mount). the car has most likely a broken shifter fork now, and i just don't have the money to fix it. the car still moves in all 6 gears and reverse, but pops out of gear very easy. not going to sell if i fix it. other than the trans the car is in 100% perfect shape. this is a great buy / winter project for someone. it was an impulse buy for me and i and i could use the cash for college debt more than anything right now. so help me out and give this rx7 a good home
some more details - 145k on the chassis. 40k on the motor. both motor and chassis vins are clean, can provide both of them. exterior is in good shape, paint looks new. nothing on the carfax though. interior is like 7/10 shape. some clips are broken, shifter boot is broken from the console. no weird smells or anything. said before, motor runs very healthy. when you fix the trans this car will be a perfect driver like it was before. will be off the market around february or march, because i will have fixed the trans by then. i can start the car up for anyone who wants to look at it. starts up fine every 5-6 days when i start it and idle it for 30 min.
car is located in nj. and like i said before, $13k is the only price you will get this car for. want to throw me a little extra, that's your call
i paid a lot more than that, it was listed for $16.5k.
i prefer you reach me at renns944@yahoo.com.
what's done to her, check out the video and pictures at the bottom:
motor2001 LS1 - 371 whp / 386 tq
ARP head studs
GM MLS head gaskets
BBK 80mm throttle body
C5 Corvette radiator / Taurus 4000 CFM fan
Walbro fuel pump
Aeromotive FPR / braided lines everywhere
factory exhaust manifolds
custom Y-pipe
custom 3" catless piping into a Magnaflow straight-through muffler
Hinson swap pieces
Deka AGM battery
drivetrain2001 T56
upgraded by sixspeedsinc
Pro 5.0 shifter, custom handle, F-body Hurst shift knob
LS6 clutch
factory 4.10 rear
Samberg rear diff mount
chassisTein Basic coilovers 12k F / 10k R
Superpro diff bushings / LCA bushings
new tophats
new pillowballs
exteriorR1 lip
interiorEfini wheel
Defi DIN gauge pod (oil pressure / oil temp / coolant temp)
new Kenwood Excelon headunit
pre-wired for sub / 10" box
have the bose sub
JasonS floormats/trunk mat
wheels/tires/brakesOEM lightweight FD wheels
245/45 Hankook RS2 all the way around
Bonez brake pads
pics/videoLS1 RX-7 rev and 40-100 pull
