March 17, 2025, 01:15:22 AM
Author Topic: Bikedads Constant Rebuild  (Read 74614 times)
Re: Bikedads Constant Rebuild
« Reply #165 on: December 28, 2014, 11:45:38 AM »
Nice Don!
Pitch the drilled rotors in the trash, they always crack like that. Good quality blank rotors are what you want to use. You can use slotted, but never drilled. Spring for the Brembo blank front rotors if you can find them. Otherwise use a name brand (Centric, Raybestos, ACDelco) professional quality blank rotors. I am running ACDelco Professional rotors in the rear right now on my car and surprisingly they have been holding up great. They were $25 shipped each from Amazon.
EBC green pads are not up to track duty as you noticed. You may also want to remove the backing plates. That will help get more air to the brakes
Offline bikedad
« Reply #166 on: December 28, 2014, 11:55:13 AM »
Fronts are probably 17x9 +24, the factory 95 Cobra R size and offset.
Rears are most likely 17x10.5 +27
I run the 17x9 +24 all around on 255/40/17 tires.
I believe you're correct Ash. I vaguely remember seeing those specs when I first got the rims.
Don Teifke  :drive:
[smg id=8489]
-----John Wayne-----
Offline dtsan
« Reply #167 on: December 28, 2014, 03:36:28 PM »
That's some good info. Glad nothing too bad happened. Your brakes looked like they got really toasty lol.  Are those rear wheels Blake's old ones?
Offline bikedad
« Reply #168 on: December 28, 2014, 04:38:33 PM »
The wheels with the ET Streets are from jasons.
Don Teifke  :drive:
[smg id=8489]
Offline dtsan
« Reply #169 on: December 28, 2014, 11:00:08 PM »
I knew those looked familiar!
Offline N2v8fcs
« Reply #170 on: December 29, 2014, 07:29:54 AM »
have you installed the Ronin 8.8 yet or you still T2?
:drive:
Offline bikedad
« Reply #171 on: December 29, 2014, 09:04:21 AM »
The Ronin 8.8 swap is still in progress Robert. That track day event was still with the TII.
I ran into a little snag with the Mustang small flange. Ford Racing sent me the 1350 and I wanted the 1310. I didn't feel like hacking into the cradle for the larger size. The 1350 was installed on the diff and lash set. I had it replaced with the 1310 and reset the lash. I had to re-verify driveshaft length also. Right now I'm waiting on my new driveshaft. Machine Service was closed over the holidays. It should be done right after New Years.
No rush. I haven't had time to work on the car anyhow. Besides, I won't be able to drive it even after it's done. We have a season up here in the great midwest called Winter and they use salt on the roads.  :D
Don Teifke  :drive:
[smg id=8489]
Offline bikedad
« Reply #172 on: December 29, 2014, 09:10:21 AM »
Nice Don!
I was talking with the instructor (Porsche guy) at the drivers dinner after the event. He said pretty much the same thing. He said if I want the pretty parts for car shows then I should purchase an extra set of rotors (like what you described) and brake pads just for track days.
I think that's what I'll do. Swapping rotors and pads takes 15 minutes and forces me to make sure they're ready for the event.
I'm also considering a six point cage with removable door bars just for a little extra protection. I don't want to hack the interior up though. It's not a true race car as I still like to cruise with it.  That will be the next project.  :)
Don Teifke  :drive:
[smg id=8489]
« Reply #173 on: December 30, 2014, 10:54:35 AM »
We have four seasons in Montana:  Spinter, Summer, snowFALL & Winter
Offline dtsan
« Reply #174 on: December 30, 2014, 11:45:37 AM »
Good ole southeast Texas has all four seasons in one week. No salt though!
Offline bikedad
« Reply #175 on: January 25, 2015, 09:06:16 PM »
The Ronin 8.8 swap is in. Haven't had a chance to drive it yet. Too much salt on the roads and my engine is winterized. (I release all the valve spring tension in Winter because I'm running solid lifters and the car doesn't get started for a few months)
My carrier is from a 2005 Ford Explorer. I ordered the Ford Racing Track Lok LSD. Ford Racing 3.73 Hobb grind gears. All bearings and seals have been replaced. A local speedshop Kilpatrick Engine & Transmission rebuilt the diff for me. They also welded the cradle mount. Axle inners were from the Explorer, shafts are Ronin and outers are GKN.
I went with the 1310 flange and a one piece slip yoke on the driveshaft.
A local company with 3 locations in Wisconsin and Illinois, Machine Service, built my driveshaft for me.
Dat asss!!  :D
« Last Edit: January 26, 2015, 03:42:45 PM by bikedad »
Don Teifke  :drive:
[smg id=8489]
« Reply #176 on: January 25, 2015, 09:14:01 PM »
Looks great!
« Reply #177 on: January 25, 2015, 09:36:00 PM »
Excellent! You are going to love it.
Offline JapCrap
« Reply #178 on: January 25, 2015, 09:41:12 PM »
Pure sex! Did you sell your other set up?
Offline bikedad
« Reply #179 on: January 25, 2015, 09:43:27 PM »
Thanks for all your help Ash. I'm excited to get it rolling. Unfortunately it just started snowing again.  :P
Don Teifke  :drive:
[smg id=8489]
