Sell it to spacevomit. He'll finish it.
Fronts are probably 17x9 +24, the factory 95 Cobra R size and offset.Rears are most likely 17x10.5 +27I run the 17x9 +24 all around on 255/40/17 tires.
That's some good info. Glad nothing too bad happened. Your brakes looked like they got really toasty lol. Are those rear wheels Blake's old ones?
have you installed the Ronin 8.8 yet or you still T2?
Nice Don!Pitch the drilled rotors in the trash, they always crack like that. Good quality blank rotors are what you want to use. You can use slotted, but never drilled. Spring for the Brembo blank front rotors if you can find them. Otherwise use a name brand (Centric, Raybestos, ACDelco) professional quality blank rotors. I am running ACDelco Professional rotors in the rear right now on my car and surprisingly they have been holding up great. They were $25 shipped each from Amazon.EBC green pads are not up to track duty as you noticed. You may also want to remove the backing plates. That will help get more air to the brakes
. We have a season up here in the great midwest called Winter and they use salt on the roads.
Excellent! You are going to love it.
