March 17, 2025, 02:18:56 AM
Author Topic: So it begins......  (Read 101792 times)
Offline screamin88
Re: So it begins......
« Reply #420 on: May 14, 2012, 04:24:49 PM »
The car just looks clean naked.
Amen...
Offline Brent
« Reply #421 on: May 14, 2012, 06:01:38 PM »
Just saw your photo's  in the FD picture thread on the 7club.  Car looks so clean... so good!  Seriously dude, job well done!
Road Atlanta August 2011 NASA TT 1:33
Traqmate's video of my car from the 2011 UTCC at VIR
http://www.youtube.com/watch?v=2Zcn6...layer_embedded
Video of Yellow LS1 FD at NASA TT at VIR
« Reply #422 on: May 14, 2012, 06:30:21 PM »
I wouldn't change a thing.
Offline r71
« Reply #423 on: May 14, 2012, 09:28:20 PM »
Thanks kids. I seriously couldn't have gotten this running without this forum.
94 FD
LS1 from 04 GTO
In Progress.....Almost done... Almost...
Build thread: http://www.norotors.com/index.php?topic=8308.msg116732#msg116732
Offline r71
« Reply #424 on: May 15, 2012, 10:21:29 AM »
Okay kids, I have a dilemma, look at where the head meets the block.[attach=1] It's always wet[attach=2]. It never sees the floor nor do you ever see it on the block. It's due to my mistake in not using enough sealant around the head bolts during installation.
So, do I rip it open to redo the head gasket? or do I drive it until it gets worse. I finally got this thing up and want to rag it out a bit. What do you guys think? Could it cause potential problems?
94 FD
LS1 from 04 GTO
« Reply #425 on: May 15, 2012, 10:23:04 AM »
The bolts holes should be dry on an LS1, so they can't leak coolant.
Offline r71
« Reply #426 on: May 15, 2012, 10:49:57 AM »
I think the trick flow guys told me I should have used extra sealant on the smaller bolts. The ones inside the valve cover. Either way, it's a very slow seepage. You couldn't even see it on the lower block, but I know it's there. I don't' know if it's going to get worse.
94 FD
LS1 from 04 GTO
« Reply #427 on: May 15, 2012, 02:07:35 PM »
Id fix it, that would bother me
that gasket set do you have on it now?
Offline r71
« Reply #428 on: May 15, 2012, 02:38:06 PM »
Stock OEM.
94 FD
LS1 from 04 GTO
« Reply #429 on: May 15, 2012, 02:43:12 PM »
That's news to me if they aren't blind holes.    I know early LS1s are, I'm 99% sure LS2s are, I don't think that changed in the later LS1s.  If so, they cannot leak coolant.   If you're leaking coolant, it's either the steam tube ports or the head gasket.
Offline r71
« Reply #430 on: May 18, 2012, 12:54:29 PM »
Way too much work to put this on. It's a straight bolt on part but since I widened the rear, I had to sand the outer edges to meet up with the new contour. It took much longer than I thought.
94 FD
LS1 from 04 GTO
Offline r71
« Reply #431 on: May 18, 2012, 12:56:58 PM »
Oh, it's good fitment but the quality is not as good as I thought. It's so thin, the light shines right through it. It could be a little thicker.
94 FD
LS1 from 04 GTO
Offline mefarri
« Reply #432 on: May 18, 2012, 05:22:20 PM »
Looks great.  Did you use some kind of weather stripping too?
-Jimlab
-Blake motherfucking McBride
Offline r71
« Reply #433 on: May 18, 2012, 05:39:17 PM »
Yeah, I didn't like the raw CF edge rubbing up against the paint. It's just your edge seal you see on lots of side skirts/ fender flares, etc..
94 FD
LS1 from 04 GTO
Offline r71
« Reply #434 on: May 24, 2012, 11:21:46 AM »
Weird, weird, weird! No leaks now. It stopped leaking. Don't get it but I'm not gonna touch it. Weird......
On another note, more jewelry!
94 FD
LS1 from 04 GTO
