The Cars, an introduction: (from Wikipedia}
The Mazda RX-7 is a sports car produced by the Japanese automaker Mazda from 1978 to 2002. The original RX-7 featured a twin-rotor Wankel rotary engine and a sporty front-midship, rear-wheel drive layout. The original RX-7 was a sports coupe. The compact and light-weight Wankel engine or rotary engine is situated slightly behind the front axle, a configuration marketed by Mazda as "front mid-engine". It was offered in America as a two-seat coupe, with optional "occasional" rear-seats in Japan, Australia, and other parts of the world.
First Generation: SA/FB
Series 1 (1979?1980)
Is commonly referred to as the "SA22C" from the first alphanumerics of the vehicle identification number. This series of RX-7 had exposed steel bumpers and a high-mounted indentation-located license plate.
In 1980 Mazda released 3000 special models known as the LS (Leather Sport). This package added an LS badge, full leather upholstery, sunroof, and gold-colored alloys. This model was only available in three different colors Aura White (1250 made), Brilliant Black (1250 made) and Solar Gold (500 made).
Series 2 (1981?1983)
Had integrated plastic-covered bumpers, wide black rubber body side moldings, wraparound taillights and updated engine control components. The GSL package provided optional 4-wheel disc brakes, front ventilated (Australian model) and clutch-type rear limited slip differential (LSD). Known as the "FB" in North America after the US Department of Transportation mandated 17 digit Vehicle Identification Number changeover. Elsewhere in the world, the 1981-1985 RX-7 retained the 'SA22C' VIN prefix. As a result, enthusiasts outside North America never picked up the "FB" nickname.
Series 3 (1984?1985)
Featured an updated lower front fascia. GSL package was continued into this series, but Mazda introduced the GSL-SE sub-model. GSL-SEs had much the same options as the GSL (clutch-type rear LSD and rear disc brakes), but the brake rotors were larger, allowing Mazda to use the more common lug nuts (versus bolts), and a new bolt pattern of 4x114.3 (4x4.5"). Also, they had upgraded suspension with stiffer springs and shocks.
The handling and acceleration of the car were noted to be of a high caliber for its day. This generation RX-7 had "live axle" 4-link rear suspension with Watt's linkage, a 50/50 weight ratio, and weighed under 2600 lb (1180 kg). It was the lightest generation of RX-7 ever produced.
Second Generation, FC
Series 4 (1986?1988)
Was available with a naturally aspirated, fuel-injected 13B, or optional turbocharged model, known as the Turbo II in the North American market, was also available.
Series 5 (1989?1992)
Featured updated styling. The Turbo II moniker was dropped, and the turbocharged model was simply dubbed Turbo.
The second generation RX-7 ("FC", VIN begins JM1FC3 or JMZFC1), still known as the "Savanna RX-7" in Japan, featured a complete restyling reminiscent of the Porsche 928. Mazda's stylists actually focused more on the Porsche 944 for their inspiration in designing the FC because the new car was being styled primarily for the American market, where the majority of first generation RX-7's had been sold. While the SA22/FB was a purer sports car, the FC tended toward the softer sport-tourer trends of its day. Handling was much improved, with less of the oversteer tendencies of the FB. Steering was more precise, with rack and pinion steering replacing the old recirculating ball steering of the FB. Disc brakes also became standard, with some models (S4: GXL, GTU, Turbo II, Convertible; S5: GXL, GTUs, Turbo, Convertible) offering four-piston front brakes. The rear seats were optional in some models of the FC RX-7, but are not commonly found in the American Market. Mazda also introduced Dynamic Tracking Suspension System (DTSS)in the 2nd generation RX-7. The revised independent rear suspension incorporated special toe control hubs which were capable of introducing a limited degree of passive rear steering under cornering loads. Mazda also introduced Auto Adjusting Suspension (AAS) in the 2nd generation RX-7. The system changed damping characteristics according to the road and driving conditions. The system compensated for camber changes and provided anti-dive and anti-squat effects. 80 lb (36 kg) heavier and more isolated than its predecessor, the FC continued to win accolades from the press. Australian Motors Mazda released a limited run of 250 'Sports' model Series 4 RX-7's; each with no power steering, power windows or rear wiper as an attempt to reduce the weight of the car.
ConvertibleMazda introduced a power operated, convertible version of the RX7 in 1988.The convertible featured a removable rigid section over the passengers and a folding textile rear section with heatable rear glass window. Mazda introduced with the convertible the first integral windblocker, a rigid panel that folded up from behind the passenger seats to block unwanted drafts from reaching the passengers ? thereby extending the driving season for the car in open mode. The convertible also featured optional headrest mounted audio speakers and a folding vinyl snap-fastened tonneau cover.
Third Generation, FD
Series 6 (1992?1995)
Was exported throughout the world and had the highest sales. Only the 1993?1995 model years were sold in the U.S. and Canada. The third and final generation of the RX-7, FD (with FD3S for the JDM and JM1FD for the USA VIN). In North America, three models were offered; the "base", the touring, and the R models. The touring FD had a sunroof, leather seats, and a complex Bose Acoustic Wave system. The R (R1 in 1993 and R2 in 1994?95) models featured stiffer suspensions, an aerodynamics package, suede seats, and Z-rated tires.
It featured an aerodynamic, futuristic-looking body design (a testament to its near 11-year lifespan). Road&Track magazine proclaimed "The ace in Mazda's sleeve is the RX-7, a car once touted as the purest, most exhilarating sports car in the world.? Handling in the FD was regarded as world-class, and it is still regarded as being one of the finest handling and best balanced cars of all time.
Series 7 (1996?1998)
Included minor changes to the car. In Japan, the Series 7 RX-7 was marketed under the Mazda brand name. The Series 7 was also sold in Australia, New Zealand and the UK. Series 7 RX-7s were produced only in right-hand-drive configuration.
Series 8 (January 1999? August 2002)
Was the final series, and was only available in the Japanese market. Improved radiator cooling was made possible by a revised frontal area. The seats, steering wheel, and front and rear lights were all changed. The rear spoiler was modified and gained adjustably.
