March 18, 2025, 01:25:40 AM
Author Topic: All things FB  (Read 29171 times)
Offline forcefed86
Re: All things FB
« Reply #105 on: September 26, 2013, 12:11:54 PM »
Looks a little tight in there!  Where’s all the details on the “go-fast” goodies used? Still have issues with cooling? Get a chance to weigh it?
5lbs of boost seems nutty low for those numbers… congrats!
Offline cyipher
  • #8 On The 50 Fastest Piston Powered V8 RX7 List
Re: All things FB
« Reply #106 on: September 26, 2013, 01:54:50 PM »
Yeah it is tight, I had to cut the radiator support out to move the radiator forward about 6 inches. The engine is still the stock bottom lq4 6.0l with the trickflow heads, I went with custom from the guy who did the cam in the old small block. Turbo is a BW S450 from forced inductions paired up with a 80lb siemens injectors on E-85. I also added a water/meth kit to help curb the IAT since im non intercooled. no weight as of yet, the trans is out of the car as the converter is at ptc getting re-stalled.
Offline Burntz
Re: All things FB
« Reply #107 on: September 27, 2013, 01:04:09 AM »
Damn that setup looks fantastic!
Re: All things FB
« Reply #108 on: September 27, 2013, 09:44:17 AM »
Nice looking kit. That is the same meth tank setup I have
Re: All things FB
« Reply #109 on: September 27, 2013, 09:47:55 AM »
So you know I forgot to turn on the intercooler pump for a pass.   Car slowed 3mph, boost went up 15kpa, and Iat at finish went from 100 to 180.
While still spraying  a single nozzle
Offline cyipher
Re: All things FB
« Reply #110 on: October 21, 2015, 09:24:57 AM »
Well lots has happened since I last updated this thread... so where to start
Well I finally got an intercooler on the car, Has this custom built from a foam mock up to a finished unit
Started to turn it up and make some power
Made headway until this pass... notice how low the mph is...
My rear end was not happy, you served me well stock 8.8 stuff
Got some new upgrades
Started to do a co2 upgrade
Tranny took a crap, 7 years at making 700-900 hp out of a th350 guess I cant complain too much
Toasted the current motor in the car, haven't ripped it out to see whats wrong but im guessing its a bent rod or rod bearing
Got a new 5.3 motor to try out to see how it stands against my 6.0
« Last Edit: October 21, 2015, 09:30:05 AM by cyipher »
Offline cyipher
Re: All things FB
« Reply #111 on: November 16, 2015, 01:22:22 PM »
old mule out...
Offline Burntz
Re: All things FB
« Reply #112 on: November 16, 2015, 07:09:17 PM »
wait wtf, ur still running stock biscuit style mounts??
Offline cyipher
Re: All things FB
« Reply #113 on: November 30, 2015, 09:04:52 AM »
actually I'm using hockey pucks with a bolt thru the center, lol.
Offline cyipher
Re: All things FB
« Reply #114 on: November 30, 2015, 09:27:31 AM »
So I Finally go the 6.0 apart, bent a rod... ooops
Got some new goodies for the 5.3 that's going back in
This is where I sit now, Waiting on a balancer tool to install that and get the oil pan on...
Offline Burntz
Re: All things FB
« Reply #115 on: March 24, 2016, 10:26:17 AM »
bump
