Good fabbing!
That circle dot between your fittings on the accumilator should be a piece of tape that was painted over. Under it probably is a window to view any bubbles in your gas.
Great eye! You were right! Once you mentioned it I knew you had to be right because I remember seeing the sight glass in the datasheet. Thanks for the heads up!
Got a little more work done in the engine bay:
Finally bought a nice little aluminum check valve for the brake booster.
Installed with my fabulous worm clamps! Alright!
Honeycombed my intake pipe to ease MAF tuning.
I'm actually 99% done with my engine bay. Apart from moving my grounds I really can't think of anything I need to do except charge my AC. I'll post pictures after I move the ground since I don't want to be ridiculed again
I've been running the engine again. My fuel pressure has moved around several times in between cranks. Its rock solid when I rev and when it idles, but I'm getting changes in-between cranks. It may have something to do with my working on the engine and/or fuel tank (fuel level gauge calibration), but its something I'm confused about and am monitoring constantly. Overall the car is running very good with the commanded idle at 900rpms. It still stumbles a little coming off of the gas into an idle condition, but the higher idle speed helps things out for the most part. Hopefully I can iron it out when I have time to tune the car.
I've also been throwing in the interior:
Door panels
Center Console wrapped in redline leather
Dash
Its coming along nicely. I'm actually planning on driving the car 5 miles to its new home tomorrow afternoon. Hopefully I won't have any issues. It'll be the furthest I've ever driven it
Lane
