March 16, 2025, 02:30:24 PM
Author Topic: 86 GXL 388sbc to 5.3 turbo  (Read 24245 times)
Re: 86 GXL 388sbc to 5.3 turbo
« Reply #90 on: July 03, 2018, 11:06:14 AM »
No there's no difference in terms of power holding ability per se. One block could be better than the other due to manufacturing variances in the casting, but there's no way to just look at them and know which without something like sonic testing or an xray (non-destructively, ie short of cutting it up).
« Last Edit: July 03, 2018, 11:12:06 AM by spacevomit »
Offline rex388
« Reply #91 on: July 03, 2018, 11:43:34 AM »
I thought the Gen IV blocks where able to handle more do to the siamese factor of the cylinders.
I think it was ERL would only really like to work with them when they were around
The only cure for drag racing is poverty
« Reply #92 on: July 03, 2018, 12:18:20 PM »
I'm not sure about that, but I do tend to go for newer stuff just because manufacturing processes tend to improve over time generally. Fwiw, I am doing an LH6 build and the rods im using (Manley forged) are rated to 775 bhp for a set of eight, so that's the number I'm using as hard limit.
Eta: I have just found that LS7 and certain non production racing blocks have siamesed cylinders due to the huge bores, could that be it?
Offline rex388
« Reply #93 on: July 03, 2018, 01:03:14 PM »
Yeah I have read on a few places that the LH6 are siamese bore to add strength to them. And my plan is to use Callies and shoot for the moon haha
Offline rex388
« Reply #94 on: July 03, 2018, 01:05:25 PM »
Also summit makes a nice little kit with LS2 lifter trays, LS7 lifters, and new bolts for getting rid of the dod.
« Reply #95 on: July 03, 2018, 01:19:53 PM »
Ok, just went and took this pic of my gen iv LH6 to clear this up. The bores are not siamesed.
Offline rex388
« Reply #96 on: July 03, 2018, 01:29:34 PM »
They are referring to it not having coolant running between them. Non Siamese the coolant can flow in-between the bores. Siamese they are just solid inbetween them.
« Reply #97 on: July 03, 2018, 01:38:01 PM »
Oh that makes sense. If more of the deck is closed then that is better. (Or otherwise increases the rigidity of the block)
Offline rex388
« Reply #98 on: July 03, 2018, 01:39:52 PM »
Exactly my friend. So in theory more abuse haha
« Reply #99 on: July 03, 2018, 02:02:28 PM »
Since you are wanting to push the envelope, on 4 bolt heads and aluminum block no less, are you doing anything special for head sealing? Some solutions use a sort of thermal/pressure fuse feature so instead of a catastrophic failure it just blows out the seal. Ie fire rings /rupture panels.
Offline rex388
« Reply #100 on: July 03, 2018, 03:27:10 PM »
I have seen a lot of people going into the 8's and a handful of 7's with L33 and lh6 engines. So Iam not that worried.
I am going to keep my lm7 also add a back up just incase.
