Wow looks like it's been a while since I posted an update, here's where we left off:
The motor showed signs of bearing wear towards the end of its first season, shortly after this event -
So the car went in the garage for the winter and I got to work, lots of big changes will be happening over the next few months.
Took the motor out, dropped the subframe, sent the motor out to the builder and started chassis prep -
Finished refinishing the 17's, added matte black Enkei stickers, and installed them on the FC for the winter so that the track tires can come inside -
Painted the engine bay and front subframe -
Finished the rear subframe, installed a new stub axle seal, installed MMR individual camber adjusters and MMR trailing arm spherical bearings, coated everything in POR-15 -
Installed a pro 5.0 shifter and steeda shift lever with a 4'' delrin knob, coated the trans in silver POR-15 -
Installed pinion snubber, cleaned and refinished the entire underbody and wheel wells with 3M rubberized undercoating (about 5 cans) -
Lots more to come, the chassis (besides a roll cage) is basically finished and ready for the new motor to come back in.
I'll post in more detail about the progress on the motor later, but I'll be picking up these super clean 243 heads this week -
