March 16, 2025, 06:12:54 PM
Author Topic: Spacevomit's FD33 Project: Behind the Candelabra  (Read 404885 times)
Offline WannaBeFast
  • Single and Looking
Re: Spacevomit's 1GZ-FE FD33 Project: Behind the Candelabra
« Reply #1110 on: September 06, 2014, 06:49:06 PM »
More like chirty five fiddy!
Offline 1320king
« Reply #1111 on: September 06, 2014, 09:23:33 PM »
Reminds me of this LOL hahaha tirty fo fitty
http://youtu.be/OO_Fc-OT1Pg?t=33s
« Reply #1112 on: September 21, 2014, 08:46:41 PM »
Tefzel loop clamps. 1/4" I.D. with #8 screw hole:
[attachimg=1]
Cleaned all the old sealant off the valve cover baffles:
[attachimg=2]
« Reply #1113 on: September 21, 2014, 08:57:59 PM »
Stainless Hydraflows, two -32 and one -40.
[attachimg=1]
« Reply #1114 on: September 30, 2014, 08:33:55 PM »
Working on an idea for my engine mounts, to grab the bolt above and below the pedestal. This is the upper part (made of 4130 ("chromoly"), the big washers are H11 tool steel) the lower part that the main bolt threads into doesn't exist yet, so use your imagination. :yay:
[attachimg=1]
« Last Edit: October 02, 2014, 02:06:09 PM by spacevomit »
« Reply #1115 on: October 02, 2014, 10:29:53 AM »
[attachimg=1]-8 Fuel Y tube. I'm using fittings and lines that have the biggest possible bore for the dash size (flexible PTFE hoses neck down internally).
« Reply #1116 on: October 02, 2014, 02:35:05 PM »
I also cut up these preformed stainless tubes from an M1 tank. I have several more of these assemblies for fabrication use. I like the flare-less/inverted 12° MS219 flare stuff a little better than the AN 37° stuff.
[attachimg=1]
[attachimg=2]
Offline Mik3ymomo
« Reply #1117 on: October 02, 2014, 03:12:30 PM »
This thing will leak like a WW1 U-Boat
« Last Edit: October 02, 2014, 05:51:00 PM by Mik3ymomo »
93 CYM Base Single Turbo
93 BB Touring 20B Swap (Sold)
Offline gc3
« Reply #1118 on: October 02, 2014, 03:53:00 PM »
those are sloppy cuts. you dont have a tube cutter?
Offline Mik3ymomo
« Reply #1119 on: October 02, 2014, 04:01:41 PM »
Is a hacksaw a tube cutter? Then yes.
« Reply #1120 on: October 02, 2014, 05:42:57 PM »
I have a band saw now, rather I have a bimetal blade for it, I did that with an angle grinder lol. I don't have a tube cutter yet.
« Reply #1121 on: October 02, 2014, 07:32:42 PM »
Pretty pretty princess!
[attachimg=1]
Offline Skeltic
« Reply #1122 on: October 02, 2014, 08:28:10 PM »
do you have any 2 cm tapered head m10  torc or  allen screws stainless or better?
« Reply #1123 on: October 03, 2014, 11:01:40 AM »
I don't have that much metric stuff in fancy alloys. This is the closest I have to that, gr 10.9 HHCS
http://www.parttarget.com/5305-01-423-5384_5305014235384_B18231B10020N.html
You can order from probolt-usa.com for stainless, 7075 and 6Al-4V metric stuff.
« Reply #1124 on: October 10, 2014, 03:30:32 PM »
[attachimg=1]
