March 17, 2025, 11:28:51 PM
Author Topic: 89' RX7 302 Swapped Vert, Track Ready  (Read 12782 times)
Offline jbguillo
« on: April 10, 2011, 01:45:05 PM »
The car has been in storage...I would rather have someone have some fun with it.
The car is a fucking blast to drive, and I've never had one motor problem, or ever gone above 210F on the hottest of tracks. Not to mention, driving this around on the street is pretty fun. The car is extremely reliable...I've never had a motor problem in the four years I've owned it. I've driven it from San Diego to LA on multiple occasions. It's just a really mechanically solid car.
While at an event in Texas, someone hit my door. The door still opens and closes, and the window still goes up and down surprisingly. It's also a little dented in the bottom left portion of the rocker, but the side skirt covers it up.
Car is located in Temecula, CA; asking 8500$
If you are interested and have questions call, text or email me.
Contact: jbguillo@gmail.com or 843-696-4143 (Jeff)
The good:
Registered, Licensed and insured in California
Title in hand
NO mechanical issues
It's badass
The bad:
Needs new passenger door
A few features:
SpeedHunters Feature
Drop Top at Full Lock | StanceWorks
Video (exhaust was removed):
V8 RX-7 Drifting at Coronado Speed Festival, September 2009 on Vimeo
YouTube - The 302 RX-7 and myself at the track...and my father riding shotgun
Without the cowl:
This is what the door currently looks like:
Most of the parts:
 Engine:
  1986 Ford 302 Roller Block
  Granny's Speed Shop Mounting Kit
  Accel DFI Gen 6 ECU
  Trick Flow Twisted Wedge Street Cylinder Heads (Incl. Trick Flow Valves, Springs, Damper Springs, Retainers, Locks, Valve Stem Seals, Rocker Arm Studs, and Valve Guides)
  Trick Flow Hydraulic Roller Cam (275/279 Duration, .499/.510 Lift)
  Trick Flow Track Heat Intake Manifold
  Trick Flow Chromemoly Pushrods
  Trick Flow Roller Rocker Arms
  Trick Flow Billet Timing Gear Set
  Trick Flow Crank and Water Pump Pulleys
  140amp Alternator
  160 Degree Thermostat
  24PSI Radiator Caps
  24lb Ford Injectors
  70mm Throttle Body
  Accel EFI Distributor
  All Seals and Gaskets are Recently Replaced
  AN PS Cooler
  ARP Head Studs
  BBK Long Tube Headers
  Custom 2.5" Exhaust
  2x Summit Shorty Glasspacks
  2x 25" Thrush Turbo Mufflers
  Custom KRC Power Steering Pump
  Custom Steel and Aeroquip PS Lines
  Edelbrock High-Flow Water Pump
  MSD 6AL Ignition Box
  MSD Blaster Coil
  Prothane Poly Motor Mounts
  Summit Aluminum Radiator w/17" Electric Fan
  Summit Catch Can
  Taylor 10.4mm Wires
  Walbro 255lph Fuel Pump
  Drivetrain:
  CorkSport Steel Brake Lines
  Custom Driveshaft
  Energy Suspension Poly  Transmission Mount
  Hawk HPS Brake Pads
  Kaaz 2-Way LSD
  Mazda Comp Front Diff Mount
  Energy Suspension Pinion Snubber/Bump Stop
  MMR Solid Rear Diff Mounts
  S4 TII Differential and Axles
  Spec 6-Puck Sprung Clutch
  Tremec 3550 Transmission
  TurboII Front and Rear Brakes
  Wilwood Hydro Master & Slave Cylinders
  Suspension:
  Custom Heim Joint Sway Endlinks
  Mazdatrix Super Angle & Bumpsteer Kit
  Racing Beat Toe Steer (DTSS) Eliminator Bushings
  Stance GR+Pro Coilovers (9k/7k)
  TC Sportline Rear Camber Bar
  Exterior:
  Work Emotion XD-9: 17x9.5 +17
  AIT G4 Aero Kit
  Custom Hood Cowl
  Interior:
  Aerospace Components Tie-Down
  Aluminum Door Cards
  Cage by Placar in Temecula
  Kirkey Roll Bar Padding
  Dash is in Perfect Condition
  Kirkey Racing Seat
  Momo Wheel
  NRG Ball-Lock Steering Wheel Quick Release
  Cusco E-Brake Button
  Optima Yellow Top
  RJS 3" 5-pt Camlock Harness Driver
  RJS 3" 4-pt Harness Passenger
« Last Edit: September 11, 2013, 02:15:33 AM by jbguillo »
-jb
Offline Dr1ft1ng0wns
Re: 89' RX7 302 Swapped Vert, Track Ready
« Reply #1 on: April 10, 2011, 01:56:34 PM »
I remember watching the videos of this thing before i started my swap, this thing was a huge inspiration. Good luck man.
87 se, roller cam 350, t56, 8.8 IRS
http://www.norotors.com/index.php?topic=41
89  Honda civic SI/Gs-r (B Series)
83 K5 Blazer on 37's
01 Civic DD
89 Chevy Crew cummins 24v powered on 37's
Offline ChippeRX7
« Reply #2 on: April 10, 2011, 03:27:03 PM »
you made me want a 5.0 swap which i am in hell with now . . . thanks alot
cant believe you are selling man, love your car!!!
GLWS
1990 GXL 5.0 w/ ported gt40p's and a T-5  ::)  . . . Dont hate me cause im poor :(
UNDER CONSTRUCTION
Offline soulless
« Reply #3 on: April 12, 2011, 09:11:57 PM »
what kind of gas mileage is the 302 getting in the fc? i've never paid any attention to ford swaps before, but this one is pretty impressive...
Offline WannaBeFast
  • Single and Looking
« Reply #4 on: April 12, 2011, 11:21:35 PM »
I think your car is pimp.
Quick question - what hood scoop is that? That's exactly what i need.
Offline jbguillo
« Reply #5 on: April 13, 2011, 06:30:09 PM »
It's actually not bad at all...I think I drove to LA at around 15-20mpg.
Made it myself haha...so I guess one of a kind.
-jb
Offline WannaBeFast
« Reply #6 on: April 13, 2011, 07:18:55 PM »
Nice mad props. I'll make one out of aluminum to resemble yours.
Offline soulless
« Reply #7 on: April 13, 2011, 08:01:27 PM »
god...i really like this thing...can tell she likes to run on the track but how are her manners for regular driving?
edit: so many questions popping up in my mind. this car is rather exciting!
Have you weighed it to see what kind of balance you have with the iron block? what does it run in the 1/4? and what kind of numbers is the 5.0 putting down?
btw I kinda hate you because I'm notorious for hating anything Ford...but damnit you're tempting me to turn to the darker dark side...lol.
« Last Edit: April 13, 2011, 08:06:51 PM by soulless »
titangts
  • Guest
« Reply #8 on: April 13, 2011, 09:44:21 PM »
dude...buy it... this is a RETARDED deal if anyone is seriously wanting to enter Pro-am...or even moving to formula D. better part is the car is 100% streetable and honestly daily drivable too.( i know cuz i had a built 302 fc DD )..
bump for a sick ass clean, amazing car for a good deal.
Offline jbguillo
« Reply #9 on: April 16, 2011, 10:04:26 PM »
I have never officially had it weighed, but I've been told by many that my setup should weigh about as much as a T2. I don't know how much truth there is to that, but it sure feels nicely balanced on track. The whole top end is aluminum now...the block is the only thing left cast.
When the motor was in a regular FC chassis it rain a low 12 and trapped 120 something on street tires. As for power....in the 4 years I've had this car, I've never dyno'd it. I would assume it's somewhere in the mid-three hundreds.
I was never a big Ford guy either, but this motor is just such a tank...I wanted something SUPER reliable on track; never 1 motor issue.
Sorry for the late response...I don't have a whole lot of free time with my current job situation right now haha.
-jb
Offline zachariah
« Reply #10 on: April 21, 2011, 01:28:42 AM »
interested in a trade plus cash from your end?
Offline jbguillo
« Reply #11 on: April 23, 2011, 02:17:29 PM »
not really looking for any trades, sorry
-jb
« Reply #12 on: April 26, 2011, 03:46:30 PM »
Always liked this one.  Sorry to see it go.
Offline Cuzzynz
« Reply #13 on: September 10, 2013, 03:21:53 PM »
this car is why i wanted to build a 302 fc.. bad ass car love it, wish i could afford it
Cuzzynz
2009 Honda Civic (Daily)
1951 Dodge Business Coupe (Project)
1989 RX7 5.0L (Toy)
Offline jerel saxon
« Reply #14 on: September 15, 2013, 10:04:35 PM »
my 5.0 fc weighs 2680 with me in it
If your having rotary problems i feel bad for you son I got v8rx7 and the bitch still runs :P
1988 rx7 gtu ford 302 HO carbureted tremec t5 grannyspeedshop kit
