cut a hole in the airdam to fix cooling with the big FMIC blocking the original flow.
Mocking up location for the odyssey battery.
Couple pics of the 8.8 sitting on the ground.
I got my oil drain line installed on the turbo. I finished all the hot pipes last week and went to install them last night but realized didn't have a T6 turbine inlet gasket. I put that on order.
Last things to fire up:
1. Install plug wires
2. Connect fuel lines to rail/FPR
3. Install battery tray
4. wire dropping resistors for injectors
5. connect wideband to megasquirt
I have not installed the wastegate on my hot piping yet, but I am going to fire it up and test a few things first. Then I'll get the WG installed. There is no danger of accidentally building too much boost with this setup during testing.
Here you can see how the flex joints are installed for each side of the engine. The pssgr pipe goes low under the pulley, the driver side goes up and then down the front of the engine. Both sides use the same type of stock stainless manifold, I bought two sets to get two matching pieces. I don't remember mandrel pipe loosing much flow at all on a 180 bend like you see in the pictures. I am waiting on the T6 gasket and then I'll snap a couple pictures of how the pipes route inside the engine bay.
