I got plates and insurance on the car. I also got the pinion snubber installed.
Started tuning on the road and found out that I am not getting a clean trigger signal to the Megasquirt from the LSx crank sensor.
I tried a couple quick tests from my past experience with megasquirt, but still the same behaviour. I am going to put a scope on the signal tonight and see what is happening. It is very likely that I am getting noise coupled into the crank sensor wire. I don't have it shielded right now and I placed megasquirt right next to the pssgr side coils.
I think I found my problem with the trigger input to megasquirt not being steady, but I have to test the fix tonight.
I was powering my LSx crank and cam sensors with 5 volts, they are suppose to be powered with 12 volts. I have been emailing dieselgeek to try to figure this out and it came up that I was using the wrong voltage due to an assumption on my part. Typical megasquirt stuff.
Well, it drives pretty nice, I had to fix a couple places where my exhasut was hitting the body. The power steering rack is capped off, but it didn't seem too bad using armstrong
The problem is that I still didn't get that crank sensor trigger cleaned up to the megasquirt, so it is like running on 7 cylinders. Still enough to dig trenches all the way up my driveway. But I can't finish the tuning until I fix this. I am still a bit perplexed. I got a good scope on the system and everything checks out OK so far. Maybe a bug yet with the code since the LS1 mode is new and AFAIK no one is running the new code version on an LS1 to confirm. Maybe coupling noise on the crank sensor wire, but I doubt that because I see problems just during cranking with the coil and injectors disconnected.
I'll keep plugging away at it, bound to fix it sooner or later. If I don't get to the track in August there is a US performance series race on October 14th and a real street race on October 13th, so I'll shoot for those.
I have had some problems in the past with megasquirt installs that took a while to iron out, but for the most part I have had really good luck with it. Might just be my turn in the barrel :dunno:
I have been through a ton of experiments and I think I got it figured out. The newest addition to the megasquirt code for the cam sensor input is not working as advertised for me. No one else has confirmed it works yet, so I am just going to build a small pulse generator circuit to bypass this problem. The pulse circuit has been confirmed by other people. So with any luck tonight or tomorrow I will have it running 100% and finish tuning.
Definitely going to be updates to the megasquirt notes once I confirm this works.
