Finally finished the exhaust after about two months haha!
<iframe width="560" height="315" src="
https://www.youtube.com/embed/FgYSCoRe2IU" frameborder="0" allowfullscreen></iframe>
I'm super happy with how quiet it turned out, the revs in the video are around 3k rpm. It is even quieter than before with the cutout open, despite the fact that I had a 4" bullet muffler on it before this. Cutout is before the bullet and HKS muffler, 4" to 3" after the cutout.
The flange welds look awesome but the pipe welds are hit or miss, as usual
. I did learn a lot more on the tig tho so that feels good. Pics:
This piece comes right off the dp at the front corner of the passenger floor board.
Had to snake it around a bit, could be why it sounds quieter?
The Ugly. Not sure why, but I couldn't get a good looking bead on any of the 4" stuff that came with my turbo kit.
This piece has some decent looking welds, comes in right behind the transmission cross member.
I only bought one piece of pre-bent piping that had one 180 and a 45 so I had to wedge this part out. Took a while to weld up but it fits nicely.
The bullet hooks up to the mid pipe right next to the passenger side ladder bar and shoots up over the axle from there.
The good, bad and the ugly all in one place.
This is where things got tight, took me a long time to finally decide how I wanted it. I have about 1/4" of clearance from the anti-roll bar link and a little more between the muffler and the fuel tank so I'll have to keep an out on those two spots. Has about 1" of tire clearance so I am happy.
Ground clearance isn't great but the suspension cross member is still significantly lower than the exhaust.
Because it wouldn't feel right without at least one blurry pic.
Aside from the exhaust, I got a new rendition of the tune uploaded and it still is hard to start
. Also put a really small spring in the wastegate and that seems to be working out well. Without any adjustments to the boost or launch controllers I was able to build 5psi on a test launch. Spun through first and hooked second just like before, so I need to bring the rpms down a bit as well as adjust the ramp rate on my EB2. Hoping I can get some sub 4 second 0-60 times without touching the suspension.
