March 18, 2025, 05:24:24 PM
Author Topic: 4.3L/4L60e TII Build for Indyparts Sr.  (Read 13533 times)
Offline rk970
Re: 4.3L/4L60e TII Build for Indyparts Sr.
« Reply #45 on: March 25, 2011, 01:58:37 PM »
one of the three center "spokes" will be really thick if it is external balanced..
« Reply #46 on: March 26, 2011, 05:02:14 PM »
Filter on, radiator and heater hoses mocked up:
[smg id=3030]
The air filter will NOT clear the hood unfortunately, but it will only require a small scoop, I think it's within 1/2" or so of clearing.   :(
Throttle cable and TV cable are installed.    TV has an adjuster kit from Summit to put the geometry right.    The throttle cable is just a stock N/A FC cable, I cut the end off and tweaked the Edelbrock bracket to fit it:
[smg id=3031]
FPR in place.   Hopefully I'll have the rest of the fuel system setup shortly.   :)
[smg id=3032]
Offline theantirotor
« Reply #47 on: March 26, 2011, 05:04:37 PM »
what about a drop base filter?
:bacon:
« Reply #48 on: March 26, 2011, 05:14:51 PM »
No clearance.    If it gets any lower it will hit the distributor and the linkages.     I did some measuring and I don't think the foam style ones will have appreciably more clearance either.
« Reply #50 on: March 26, 2011, 05:23:02 PM »
.1" shorter than the current one.  ;)
Trust me, I did some research to find the best chance of clearance.    Short of building something custom, this is as good as it gets, and something low enough to clear would only be 1/4" above the choke tower.    It's not a race car, but I'd like to make sure all 4 barrels can get air.  ;)
Offline IndyParts
« Reply #51 on: March 26, 2011, 06:07:51 PM »
So what are you saying? lol
Will there have to be a hole cut?
« Reply #52 on: March 26, 2011, 11:08:16 PM »
Yes, there will have to be a hole.
Offline bikedad
« Reply #53 on: March 27, 2011, 09:54:05 AM »
Hey Blake,
My scoop  is the Cobra Jet style. Has a low profile but maintains some sense of stock look.
I cut off about 4" from the back of the scoop and opened the front.
My hole in the hood is about 1/4 in larger circumference than the air cleaner. With a K&N cloth filter I've not had any problems driving in the rain.
Actually with the slope of the hood I've not even seen water trails go into the scoop area. I think it literally blows over the top. (I can't completely confirm that as I don't have a wind tunnel to test. LOL)
The pictures show my old Edelbrock foam cleaner but I currently have an 8" Chrome similar to the one you show with a K&N filter.
[smg id=425]
[smg id=422]
[smg id=1679]
Just some ideas. You can delete this post so it doesn't clutter the thread.
Don Teifke  :drive:
[smg id=8489]
-----John Wayne-----
Offline Defenistrator
« Reply #54 on: March 27, 2011, 11:02:34 AM »
I think Don's scoop looks pretty good, and getting some cool air to that v6 will probably make a significant difference in power as well.
For clearance though, MAYBE something like this would work?
http://cgi.ebay.com/ebaymotors/GM-V8-350-305-TBI-VORTEC-AIR-INTAKE-FILTER-KIT-SYSTEM-_W0QQcmdZViewItemQQhashZitem51984d4863QQitemZ350447552611QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
I'm pretty sure those GM TBI lids have the same diameter as the carb mount.
« Reply #55 on: April 08, 2011, 11:55:29 AM »
Ordered up the brackets from Granny's for the alternator and power steering, and the lower radiator hose.
Received the crank balancer (both were internally balanced style), and the timing pointer.
Need to get that stuff installed, install the oil and water temp senders and get some fluids in it.   Should be nearly ready to start.   :)
-Blake
edit:  Just ordered up the Dakota Digital and Integra Speedo to make the factory gauges function fully with this setup.   :)    Just need an N/A rear driveshaft flange and to get the driveshaft modified (and to get out there and get to work!) and we should be heating coolant.
« Last Edit: April 08, 2011, 12:54:26 PM by digitalsolo »
Offline N2v8fcs
« Reply #56 on: April 09, 2011, 10:47:07 PM »
I used the '79-82 mustang/capri  replica scoop on my carbureted SBC build . Scoop "mimics" the T2 scoop .
:drive:
Offline WannaBeFast
  • Single and Looking
« Reply #57 on: April 09, 2011, 11:06:55 PM »
it's going to be a very reliable setup when completed.  TTU (Two Thumbs Up)
Offline yamaha
« Reply #58 on: April 10, 2011, 12:19:03 PM »
Do you still plan on using the ECU to control the transmission? Looks good!
« Reply #59 on: April 10, 2011, 03:33:14 PM »
It's not an ECU controlled transmission.   :)    That was the pivotal part of my decision to run a carb on it.
Thanks!
