March 18, 2025, 01:56:17 PM
Author Topic: Power steering line  (Read 19539 times)
Offline RX7what
Power steering line
« on: May 17, 2010, 02:18:12 PM »
I know you make lines for the fbody pump. I was wondering if you could make me one for a LS2 pump. It comes out of the top so it would need a extra 90 so it points down.
PER AUDACIA AD ASTRA
Offline Pez
Re: Power steering line
« Reply #1 on: May 17, 2010, 04:06:35 PM »
Yup, I add a female -6 to male -6 90 to make it compatible with the LS2 pump.
Offline RX7what
« Reply #2 on: May 17, 2010, 06:34:03 PM »
How much :) pm me.
Offline hayabusa
« Reply #3 on: May 17, 2010, 07:51:52 PM »
how musicch for a ls1 gto powersteering line
Offline Pez
« Reply #4 on: May 17, 2010, 07:55:03 PM »
$110 for FD with Fbody pump, $125 for GTO or LS2, and $125 for FC shipped for the PS lines.  I need to make another thread about the stuff I offer, just been too busy.
Specify black or blue hose and LS1 or LS2 in your payment.  Thanks.
« Last Edit: March 01, 2013, 10:00:37 PM by Pez »
Offline Turbo95max
« Reply #5 on: June 02, 2010, 11:07:55 PM »
do you have any pics of the line installed? I PMed you a couple times but havent gotten a response. Thanks
Matthel Ma
93 RX7 LS7
13 Ford Raptor
95 turbo Maxima
03 Police Interceptor P71
www.theshopsanbruno.com
Offline tweak
« Reply #6 on: June 06, 2010, 01:59:37 AM »
Are they for FC or FD?
Red 88 FC GTU - 2000 LS1  - 3 stage 6 gallon dry sump - Stock LS1, T101A transmission - Stance coilovers .... lots of tires.
Offline willcoop
« Reply #7 on: June 18, 2010, 01:17:11 PM »
Do you have FC power steering lines in stock? If not how long does it take for you to get them?
Offline Pez
« Reply #8 on: June 20, 2010, 12:31:00 AM »
I have everything in stock to put FD lines together.  The problem that I have with FC lines is the rack fitting is ment for a banjo bolt, and the threads start about 3/8" in the rack.  The only time I've made a PS line for an FC, I had to make the banjo bolt because all of the aftermarket banjo bolts were too short.
There hasn't been much of a demand for FC PS lines, but there looks to be now.  I've got access to a lathe, so I guess I could spin out a few bolts.  The banjo fittings are a bit priceyer than the fittings I use for FDs, so I could probably do an FC kit for $125ish.
Offline turtle m3th
« Reply #9 on: June 20, 2010, 01:14:37 AM »
I'd be down for an fc kit.
Offline tweak
« Reply #10 on: June 20, 2010, 01:21:09 PM »
+1 but I need a realistic time when it will be shipped out.   You seem to be quite busy.
« Last Edit: June 20, 2010, 03:54:25 PM by Pez »
Offline willcoop
« Reply #11 on: June 20, 2010, 01:55:55 PM »
x2
Offline Pez
« Reply #12 on: June 20, 2010, 03:54:37 PM »
I could probably get them out by the end of the week as I'll have to order the banjo fittings and make the bolts.  I have everything else needed on hand.
I'll go ahead and order enought for 5 or 6 kits.
Offline tweak
« Reply #13 on: June 29, 2010, 11:16:31 PM »
I would love to grab a set of these, how do I get on the list?  Did you mean the end of last week or this week?
Offline lm38330
« Reply #14 on: July 04, 2010, 05:58:25 PM »
count me in for a set of FC ps lines.i will be using f-body ps setup
