March 14, 2025, 07:19:49 AM
Author Topic: Has anyone broken a 8.8 IRS? We did...  (Read 16369 times)
Offline Demon
« on: January 02, 2011, 09:55:30 PM »
Started pulling the rear end out to freshen it up/check on it after many hard launches this year (30 or so 1.4 60' times)
Found this:
We have a backup rear end, so we'll switch to that and the aluminum hard bushings, instead of the poly bushing that obviously failed and allowed the diff to break.
'93 RX7 (co-project with macnewma)
'95 Supra Turbo Billet GT42-76
Offline Rayminator
Re: Has anyone broken a 8.8 IRS? We did...
« Reply #1 on: January 02, 2011, 10:11:40 PM »
Interesting breakage.
I would be installing a pinion snubber, or a loop over the top of the housing, anchored at the same mounting points, to keep the ears from flexing.
What makes you think, that solid mounting the ears, would not cause the same damage?
Offline BeasTT
  • Twinz for teh winz
« Reply #2 on: January 02, 2011, 10:12:55 PM »
And that's why I run the cast iron housings :D
Nick Shultz
1993 Rx-7
Offline Demon
« Reply #3 on: January 02, 2011, 10:18:52 PM »
The shape of the break is exactly the same shape as the break of the poly bushing that's torn, I think it let it give and twist causing it to break where it doesn't have as much surface against the bushing.
Offline BeasTT
« Reply #4 on: January 02, 2011, 10:25:43 PM »
Gotcha. I'll have to keep an eye on mine, but my bushings are red, so hopefully they're better :)
Nick Shultz
1993 Rx-7
Offline theantirotor
« Reply #5 on: January 02, 2011, 10:39:02 PM »
The ear breaking could have also caused the bushing to get torn away.
:bacon:
Offline ablake211
« Reply #6 on: January 02, 2011, 10:43:31 PM »
Iron housing and solid bushings here.
Offline Rayminator
« Reply #7 on: January 02, 2011, 10:49:40 PM »
"The ear breaking could have also caused the bushing to get torn away".
I just wrote the same exact thing, but my post did not go through.
Yes, it appears that the break may have sheared the bushing, then bent the washer, when the housing raised up.
Offline Speedfab
« Reply #8 on: January 02, 2011, 11:30:58 PM »
It's the way it was mounted.  The support and structure needs to be ABOVE the nose of the diff, not below it.  A couple of washers on top of the bushings won't f$%king cut it.  Cobras with factory engineered subframes 1000 pounds heavier making twice the power of your car don't have that problem... guess why.
Don't blame the diff housing, it isn't at fault.  If you want a subframe that won't cause that to happen, shoot me a PM.
« Reply #9 on: January 02, 2011, 11:31:23 PM »
You may want to make a brace that goes across the top of the 2 front diff mounts for extra support.
That broke because of the poly bushings. Use solid bushings and you will be less likely to have that problem again.
These diff housings as a rule never break in Cobras.
I have an empty Mark VIII/ Cobra aluminium center section if you want it. Shoot me a PM if you are interested.
« Last Edit: January 03, 2011, 12:02:36 AM by largeorangefont »
Offline mefarri
« Reply #10 on: January 03, 2011, 12:30:40 AM »
So would Justin's mount be the right way?
-Jimlab
-Blake motherfucking McBride
« Reply #11 on: January 03, 2011, 12:37:59 AM »
That's a negative ghostrider.
Offline Demon
« Reply #12 on: January 03, 2011, 10:30:45 AM »
I knew you were good at flipping things over :).
I may get in contact with you, thanks!
« Reply #13 on: January 03, 2011, 10:31:44 AM »
get back to work!
:bacon:
Offline DeaconBlue
« Reply #14 on: January 03, 2011, 11:20:56 AM »
Very good point.  Take a look at a photo of a 2003-04 Cobra rear setup out of the car, like here;
http://www.mpsautosalvage.com/sunshop/index.php?l=product_detail&p=2812
Most of the nose weight of the unit maybe carried by the lower mounting bracket, but the twisting motion is controlled by both the lower  and upper brackets, which work in tandum to brace the differential case and share in resisting the twisting motion, during both on and off throttle (acceleration and deceleration) loading.
