The ground clearance saga continues....
As you can see in this pic I have serious ground clearance issues.
The guy who back-halfed my car took very little time planning and just got the regular nova/mustang/camaro style techniques to this build. The very first bar he put in this car is the low hanging ladder bar crossmember. I can't imagine the logic behind the the first bar being put in a race car taking away 5+ inches of ground clearance.
I took the car back to him twice and asked him both times to fix it to which he declared "it will mess up the structure of the car".
So I replaced it yesterday. It came out pretty good. It is now even with the frame rails and ladder bar brackets. Jacked the car up by the new xmembet after I built it do I guess it will hold!
I will add some pics after I get the welds ground down and painted.
The other issue I have it that when dude put the tubs in the car he didn't give me as much room as I wanted. They are plenty wide as I can fit a maximum of a 13" wide tread slick (14.5 at the widest of sidewall) but I wish I had mote height so I can get the car as low as I would like.
I really like the way the car sits in this picture...
BUT the car had 31x10.5w tires at this point and the tires were sitting on the tubs and would not even turn. I have a good idea of how I can fix this and actually lose weight in the process!
The tires on the car now are 295/65/15 drag radials. I am planning on cutting the tubs out (a large portion of them at least) and replacing them with carbon fiber that will fill in from the down bars to the quarter pannel trim (which is already carbon).
The following pic Is of the driverside wheel tub.
I am planning on fitting a piece of carbon on between the down bar (long vertical bar) and cutting it at the angle of the diagonal bar. This would give me at least a few more inches based on the angle of the diagonal bar. That bar is flush with the top of the tub where it meets the down bar but this shouldn't be an issue as the indide of the tire is around 5" from the inside of the wheel tub.
Then hopefully I can put this thing on the ground and drive it that way too!
