April 01, 2025, 01:36:24 AM
Author Topic: What ARP wheel studs do I need?  (Read 94792 times)
Offline blufc3s
Re: What ARP wheel studs do I need?
« Reply #15 on: December 22, 2010, 02:29:04 PM »
I have the rear hubs off the car and plan to do this as well.  For about $50 per side for studs and bearings it is good peace of mind and not leave ya stranded.
I haven't really heard of anyone shearing off stock wheel studs.... but it would certainly mess up your body on the car if it did.
I have aftermarket "Bullet" wheels & I am losing a few turns on the studs from stock, so I've been a little concerned about it.
Stew
87 TurboII LT1/4L60E donor 95Z28
Long tube 1 5/8" headers,electric cutouts,Magnaflow Hughes 3000 stall L/U conv.
CC 276HR cam, Bullet vs2700 valve springs,TFS hardened push rods, ARP studs,
30 lb Bosh inj. ,Scorpion SA RR's, Supra TT fuel pump,March reducer pulley K&N CAI,
 line lock,MT 255/16 Drag radials,Spherical rear LCA bushings,MMR camber adjusters      1.615 60`,11.84@115.54 MPH.
Offline ablake211
« Reply #16 on: December 22, 2010, 09:21:03 PM »
I used the longer ones on all four corners.
Offline mpcv2000
« Reply #17 on: January 19, 2011, 10:52:32 AM »
I don't know if I did something wrong but I bought some ARP # 100-7708 2.5" long studs but they are too long for my 89 Turbo II running 5Zigen FN01R .
Left side is the 100-7708 studs and right stock rear Turbo II studs :
Way too long for my need unless I did something wrong.  :confused:
I've decided to cut 1/2" and they look way better.
I haven't took the front wheels off the car yet but looks like the 100-7713 3.5" studs will be way too long.
Why FC people run studs soo long ?
For sure the rear ( stock ) studs were way too short :
Martin !
« Reply #18 on: January 19, 2011, 11:21:52 AM »
That's how they normally look (the extended studs).  :)
Offline mpcv2000
« Reply #19 on: January 19, 2011, 11:49:46 AM »
Ok cool so no need for me to be that long , glad I cut them.
Thanks Blake.  :cheers:
Martin !
Offline FCs Rule
« Reply #20 on: January 19, 2011, 11:50:20 AM »
http://www.summitracing.com/parts/ARP-100-7713/
http://www.summitracing.com/parts/ARP-100-7708/
those are the two that i ordered
before
after
installed and compared
i did replace my wheel bearing while i was there and i had a press to use at the time.
._________________________
Offline FCs Rule
« Reply #21 on: January 19, 2011, 11:51:18 AM »
i left mine long because i like the look of it for some reason..lol
Offline mpcv2000
« Reply #22 on: January 19, 2011, 11:59:36 AM »
...and I did cut mine because I didn't like the look......... ;)
Martin !
Offline AndreS
« Reply #23 on: January 20, 2011, 03:06:37 AM »
Quote
mostly to meet sanctioning body rules for safety with wheels that have really thick hubs.
here's a pic of the 7708s on the front
88 RX7 'SE'- LS1/4L60E, yank SS3600, T2 diff, S5 NA 5 lug swap, KYB struts, etc.... best 1/4: 11.575 @ 117, 1.59 60'.
Offline FCs Rule
« Reply #24 on: January 20, 2011, 02:06:19 PM »
well you are from canada..lol
Offline mpcv2000
« Reply #25 on: April 18, 2011, 08:00:46 AM »
Just updating this thread for people using the "search" fonction.
I have ordered the 100-7708 for the front and they work perfectly ( for me at least ) .
Stock front studs with my FN01R-C 5Zigen  ( only 1/2 lenght of the lug nut is screwed on the stud ) :
ARP #100-7708 vs Stock :
Now on the car :
Since day 1 of owning the car the front lug nuts were down on the studs about 5 threads and it was bugging me so this week end I had to put new brakes , it was the perfect time for studs replacements , glad I didn't buy the 3.5" ARP # 100-7713 ( way too long for my need ) . :drive:
Martin !
Offline FCs Rule
« Reply #26 on: April 18, 2011, 08:11:59 AM »
I made this topic a sticky so others can see what parts to use
Offline mpcv2000
« Reply #27 on: April 18, 2011, 08:49:51 AM »
Good idea.  :)
Martin !
Offline rex388
« Reply #28 on: August 11, 2011, 11:13:18 PM »
So the 2.5" studs leave enough stick out for IHRA and NHRA rules?
Offline Troux
« Reply #29 on: August 14, 2011, 04:31:32 PM »
This is something I never really considered. How would one know if they'll need longer studs before putting the wheels on?
