Got the exhaust finished up yesterday, and it was the most labor intensive project yet on the car. Part of that was due to not having a lift for the car, and also because I was learning how to do it. I want to thank Don Teifke (bikedad) for posting the great photos of his new exhaust. I used them as a guide in building mine. I bought 2 J-bends and 2 U-bends, 2 straight 4-foot sections, the Summit narrow X pipe, 2 Jegs ball and socket couplers, and 2 Summit Turbo mufflers. I had the Magnaflow on a previous car and it was a little loud for me, especially after a year of driving. I’m still learning how to weld, but getting better at it, only half of my welds look like piled up buggers.
A few things I learned on this project:
1.The mandrel bends are about 1/8 inch smaller diameter than the straight section, not a big deal when welding, but there will be a ridge on the inside. If I had to do it again, I might invest in a bender for bends less than 20 degrees.
2.When welding the tubing, rotate it so you are always welding down the side, so that gravity helps pull the bead along. If you weld directly on top, gravity wants to pull the bead inside the tube, and you get a burn through.
3.Burn throughs are not a big deal, just let it cool down and go back and fill it in. I duct taped the ends and put low pressure air in the pipes and checked the welds for pin holes with soapy water. Marked them and went back and tacked them shut.
I welded in O2 bungs on both sides in case I get a wideband gauge or switch to EFI down the road. The Jegs ball and socket couplers are nice that they allow a little bit of angle if the pipes are not exactly lined up. When I was done welding, I painted everything with the Dupli-color ceramic engine paint (cast iron). I don’t know if it will last, but it might keep the welds from getting rusty.
Don's exhaust photos taped to the window:
My welding rig, an old copier cart from the office:
Pieces tacked and ready to be welded:
Jegs couplers:
O2 bung:
My custom 20 degree slant cut tip:
This is all I had left over when I was done:
