March 16, 2025, 02:30:43 PM
Author Topic: Sufficient fuel system for 500rwhp?  (Read 31744 times)
Offline 93silverbullet
  • Faster than a speeding ticket...
Re: Sufficient fuel system for 500rwhp?
« Reply #15 on: October 27, 2010, 01:05:39 PM »
Now I'll wait here for someone to post up that stock injectors are fine because their cousin's uncle's son used them in his 1200 HP Camaro.  ;)
For the last time... it wasn't a Camaro! It was a 9 second Supra!  ;)
Richard.
Offline mattster03
« Reply #16 on: October 27, 2010, 01:56:40 PM »
If the green tops are rated 42@40 psi then they will flow 50.5@58 psi.  I echo the sentiments that you should improve your fuel pump situation, but the injectors are plenty for now.  You have headroom on your already generous 80% duty cycle.
HOWEVER
BSFC is calculated using flywheel horsepower.  You basically need to support 580-600 horsepower.
(600*.6)/(8*.8) = 56.25
No dice.  However 600@ 90% duty cycle is 50 lb/hr.  You would be pretty much right there.  With a supercharged car it would not be something I would want to worry about.
Green tops really should be fine UP TO 500 HP.    Go much beyond that and you lose the "20% safety margin".
For 100 bucks, I'd buy them just resell, that's a steal.
My cousin's uncle's son's car didn't even use injectors.  He just put like 8 walbros on the intake manifold.  It made 1200hp on low boost without a tune!
Wow, thanks for the heads up on that... I guess I'm shifting back towards looking into finding a good set of 60lb/hr injectors.
Offline theantirotor
« Reply #17 on: October 27, 2010, 02:29:08 PM »
i'll take the greentops.  :)
:bacon:
Offline HTh3r0
  • Cleanest engine bay crew
« Reply #18 on: October 27, 2010, 02:45:21 PM »
i got my fms greens for 100. Haha. Anyway. . At 400ish i still have alot of injector left. I'm using a supra pump that has been reworked or some crap. I could use a super and a pad for all that flow. Just my .0000002.
10.9@128   :bacon:
1990 GXL ls1/t56 up for sale.
http://www.norotors.com/index.php?topic=7089.msg100073#msg100073
« Reply #19 on: October 27, 2010, 03:59:24 PM »
Exactly how much power do you have and what are you injector duty cycles?
Offline mattster03
« Reply #20 on: October 27, 2010, 04:18:17 PM »
Another question: do you have to account for the boost pressure in the cylinder working against the fuel system pressure? For example, if my fuel system is at 58psi and I am running 8 lbs of boost, can I really only account for 50psi fuel pressure?
Offline Sabre002
« Reply #21 on: October 27, 2010, 04:55:43 PM »
thats where the vacumm line to the FPR comes into play.  I would assume you need to account for that pressure.
Josh
Jsmit295@mazdausa.com
« Reply #22 on: October 27, 2010, 05:29:34 PM »
Exactly, that's what a boost-referencing (1:1) FPR does.  Should already be taken care of by your FPR.
Offline mattster03
« Reply #23 on: October 27, 2010, 05:32:29 PM »
correct me if i'm wrong, but i believe i'll need an aftermarket FPR then?  considering I believe my corvette FPR doesn't have a vacuum reference port? holy ish this is starting to cost more than i expected  :( . good thing i'm laying it all out first instead of buying parts  :P
« Last Edit: October 27, 2010, 05:36:35 PM by mattster03 »
Offline Pez
« Reply #24 on: October 27, 2010, 08:54:06 PM »
Stock Vette FPR won't support 500hp.  I doubt the stock Mazda fuel lines will support 500hp.  Yes, the lines that run all the way back AND into your fuel tank.  O, and when you loose your FPR, you also loose your filter, so you'll need a new filter..... one that can support 500hp.
Expect $500 on a cheep fuel system.
FC/FD plug and play wiring harnesses, LSx swap AC systems, LSx swap power steering lines.
Offline mattster03
« Reply #25 on: October 27, 2010, 09:15:32 PM »
Well I am all ready running -AN lines, but it's kinda cheating b/c it's only -AN to the FPR which is near the diff... it's mazda to the tank after that.  $500 would be a dream... i'm suddenly staring $800.00 in the eyes!
60lb injectors: $350
Bosch 044: $200
FPR: $150
Lines, fittings, etc: $100
Of course I could probably sell my corvette FPR and Supra pump for $150 to make up a few dollars... but still!
Offline Pez
« Reply #26 on: October 27, 2010, 09:26:25 PM »
nm, I wasn't including injectors in my price.  I was talking about lines, pump(s), fittings, fpr, filter, rail, etc. And $100 in lines/fittings is cheep.
Offline Sabre002
« Reply #27 on: October 27, 2010, 09:52:48 PM »
Matt I got like 700 in my fuel system for the 402.  its not cheap when you want to make power.
Josh
Offline BeasTT
  • Twinz for teh winz
« Reply #28 on: October 27, 2010, 11:15:49 PM »
I have well over a grand in mine, but the peace of mind is priceless.
Nick Shultz
1993 Rx-7
Offline RX7what
« Reply #29 on: October 27, 2010, 11:44:11 PM »
I put aside more like 150-200 for the lines and fittings. I have over $140 worth of fittings and lines in my engine bay alone.
By the way summit makes some nice house brand AN fittings you can get in black. They are also a little cheaper than the earls stuff.  I have a bunch of part numbers if you want them.
PER AUDACIA AD ASTRA
95 FD #496/499 LS2   http://www.norotors.com/index.php?topic=4789.0
Norotors is far and away the best car forum on the Internet, bar none.
