September gets crazy busy for us. Managed to get a solid 5-6 hours in yesterday on wiring and cleaning things up. Most of it spent shoved up under the dash.
Its at that stage where it feels like a lot of work goes in, but no apparent progress is seen lol.
A few things - The Holley harness has a beefy 10 gauge power and ground that feeds the ECU which connects direct to the battery. I was able to get this out of the engine bay, run it under my carpet and into the bins where my new battery is completely out of sight.
I also cut the main harness and my transmission harness loose and pulled it back into the car, fixed some tangled bits, and routed it back behind the brake line like I was supposed to do when I put the engine in lol.
Also was able to get some loom around some of the wires that branch out of that area to clean it up a bit. This really cleaned up the wiring in the engine bay.
Lastly, spliced my Halfspec AC controller back into the car. I was going to integrate it into fully into the Holley, but with the limited I/O, and already having the AC controller on-hand it was easy enough to patch it back in, and this saves me multiple I/O. I can run the AC now with no I/O, or with a single input probably get all the functionality I could hope for.
I believe I have also figured out a clean way to tuck all the excess harness inside the car. So far it appears like the majority of it will fit in a cubby hole behind the ECU in the passenger kick panel, and there should be room for the rest of it behind the plastic if there's any excess that won't tuck away nicely.
Last piece is going to be finding a home for the I/O expansion module, and making a new harness to run to my sensors and relays. The expansion module is about 3"x4" x2" high. I'm hoping I can just stash it behind my dash as I'll already have my CAN extension harness running that way for the digital dash. What's nice is power and ground is fed via CAN.
In the I/O harness needs to be:
Speed sensor input (input)
Cooling fan relay (output)
AC activation (input)
Clutch switch/2 step logic (input)
Flex fuel (PWM) (input)
Alternator voltage control (PWM) (output)
2nd fuel pump relay control (output)
Oil temperature (input)
Tach signal (output) - Holley puts out 4 pulse per rev only from the ECU..
Future plans if I have extra I/O:
Activation wire for a keyed 12V source front and rear of the car (could be shorted together) (output)
Coolant pressure sensor (would've caught my coolant leak much earlier) (input)
PWM wire for a potential different Electric water pump (output)
??? not sure what else but if I have anything leftover I'll just send spare wires to the front and back and tuck them away somewhere.
