March 15, 2025, 10:47:59 AM
Author Topic: 403 LS2 FD - LS7 Build for 2020!  (Read 278767 times)
Re: White 94 Cali legal 404 stroker ls2 swap
« Reply #285 on: December 03, 2014, 04:55:43 PM »
Cool!  Figured as much.
What is that mesh that harness mesh stuff you use?
Offline deepfriedbutter
« Reply #287 on: December 03, 2014, 08:12:10 PM »
Does the LS2 have a secondary air pump? If so, what did you do with it? Also, what are you doing about fuel lines, regulator, charcoal canister, etc. to get it CA legal?
« Reply #288 on: December 03, 2014, 09:53:49 PM »
No air pump on the ls2.  This post should answer the rest of your questions.
If you're starting a CA Ref'ed build now I highly suggest using the E-rod.
http://www.norotors.com/index.php?topic=312.msg30668#msg30668
Offline Jordan Innovations
    • Jordan Innovations
« Reply #289 on: December 03, 2014, 11:34:56 PM »
I just looked up the Bosch pump and at 4 bar it pulls 12 amps.
Negative, maybe free-flow it'll drop to 12 amps, but full-bore those will pop a 20A fuse.  Something like 15A nominal, use a 25A or 30A fuse/breaker.
Offline halfspec
« Reply #290 on: December 04, 2014, 07:12:13 AM »
I don't think anyone in this thread said to fuse the circuit with a 20A fuse. In fact I told Daniel not to worry about fuses as every circuit in the front relay box is fused externally and the stock fuse is 30A.
Lane
« Reply #291 on: December 21, 2014, 07:31:07 PM »
IT CRANKED!
Just bumped the starter for the first time successfully.  First start is just around the corner.  Unfortunately I have dinner plans all tonight...
Started with only 4 volts at the starter solenoid and nothing.  Jumped the clutch switch and got to 5.2 volts and got a click.
This car had a turbo timer and a "star guard" in it when I got it.  Was NOT fun but I just got all that garbage out and now the bitch cranks.
Offline paul_3rdgen
« Reply #292 on: December 21, 2014, 07:51:09 PM »
Congrats!  It feels so good when you know all that hard work is about to pay off.
93 RX7 R1 500rwhp
LS2, H/C combo... ARE drysump
« Reply #293 on: December 21, 2014, 07:56:37 PM »
Sweet!
Offline mattster03
« Reply #294 on: December 22, 2014, 02:40:11 AM »
Very much approve.
« Reply #295 on: December 22, 2014, 11:56:44 AM »
Can't wait to hear it run.... your impressions and it pass CA smog!
« Reply #296 on: December 25, 2014, 02:33:21 AM »
Will this clear the hood?
Offline 4packet
« Reply #297 on: December 25, 2014, 06:42:50 AM »
No  ;)
« Reply #298 on: December 25, 2014, 08:59:07 AM »
That depends, does your hood have a giant ass hole right where that tube is?  If so, yes, it will clear fine!
« Reply #299 on: December 25, 2014, 01:49:02 PM »
WTF are you trying to do there buddy?
