Thanks Holmes!
I disliked the video because you are convincing me to forgo my kid's Christmas gifts this year to buy an LS7.
Damn hahaha. I got this complete engine w/ recently serviced heads for only $5500 before I dumped a little money into it
I've seen LS3's listed for more money. The powerplant is killer so far. I think on break-in I probably need another 480 miles on the clutch and trans lmao. The new ring and pinion are probably broken in by now. I need to wrap the rest of the car up now so I can put some windshield time in.
Reflecting back on today, the engine did seem to run better and more consistent today. I think the timing was moving around as the crankshaft was losing position. I got on it a good 3-4 times today and it ran great each time. One of them I rev matched down to 2nd and hooked it around a corner and rolled into 2nd gear and it drove into a light wheel spin. It didn't blow the tires off so I thought it would hook up eventually, but as the RPM climbed it just kept hazing the tire until I lifted around 6000 lol. I am so far really quite stoked on the power delivery with this short runner intake it is super fun. Hazing 275 wide slicks in the midrange - not seeming short on torque lol. I can't wait to start banging gears and driving it hard.
With the ignition problem resolved I was honestly a little stunned and didn't know what to do next lol. NGL I lost quite a bit of time texting everyone I could think of hahaha.
I futzed around a bunch with the I/O expansion module. Took me a while to understand how to communicate with it in Holley's software. The I/O's aren't the most intuitive in their software overall. I spent quite a bit of time trying to plan these remaining wires and programming all my added I/O.
I ran a couple wires back to my trunk area for controlling my second fuel pump, and to try and wire into my fuel level sender as my Speedhut gauge has been stuck on full no matter what. Well, the fuel pump wire works, but my fuel level sender still reads 100%. I may be stuck pulling that surge tank back out of the gas tank to check the wiring, but I just put a full tank of gas in it unfortunately.
I also tried the AC again today and it seems to not be cycling on. I'm hoping I don't have a leak.
And lastly, now that I could communicate with it via the I/O module, I see that my flex fuel sensor is not reading unless Chevron pumps E0 now which I know is not going to be true in California lol.
So I'm still in a bit of wiring hell, mixed with troubleshooting and learning the Holley, but it should be forward motion only from here on.
Also, this! Way stoked about this beast of an oil cooler from Improved Racing. It's a triple pass, and holds 2 quarts on its own not counting the lines. They say it can support endless lapping in a 650+ hp corvette in the same orientation I want to install mine. I've never had one on this car, and coincidentally I've also never had an oil temp gauge. I got one of their thermostat adapters that mounts where the oil filter is. I got the 212* thermostat since my cooler is so large lol.
Now that I moved my battery to the trunk I have all this space down low behind the radiator. I'm going to mount it parallel to the ground with a small air dam - maybe a printed scoop or something to promote air to pass through it.
