I'm keeping my steering rack!!!!! My old man tackled it while I was wiring. He was able to drill and pull out the side seal without taking the rack apart. Just had to remove the inner tie rod on the one side. Such a relief.
I posted up on the Facebook group so I think everyone saw already, but I was able to go for a real drive! Took it out for 10-15 minutes and everything was perfect. I only got into it really lightly on the throttle. Just cracking this big throttle body gives you a lot of air, so I didn't putt around, but I really only got into it maybe 20% throttle. The clutch, trans and r&p all need to break in and have fluids swapped out.
The new catch can routing is working perfectly. Not a wisp of smoke came out. You no longer smell like burnt oil after a drive (I'm hoping that remains true, maybe a real test will be a longer drive).
The Tilton clutch has a slight shudder on take-off, but my tune is horrible just off idle. Right when the car starts moving the engine almost dies unless you feed it a lot of revs so I'm thinking with tune improvements and some break-in miles it should smooth out. It feels good and natural to drive I'm liking it a lot so far. Great news is the sprung hub and strapped floaters fully resolved my 1800 rpm vibration. There's still noise at that RPM you can tell it is a harmonic point in the drivetrain, but there's no vibration coming into the cabin.
I have just a touch too little clutch travel at the moment. I need to see if I can adjust the clutch rod enough, or if I need to modify the pedal. I'm feeling like I can't quite get it into 1st gear sometimes at a dead stop. If the car rolls a little it falls right in. I also had it balk on me going into gear a little if I wasn't perfectly on the floor (happened in the video going into 5th lol). I don't think this is a matter of break-in, I think I'll wind up hurting the syncros if I don't fix it. I'm going to be no lift shifting this thing so I want to make sure the clutch is fully disengaging lol.
On the topic of vibration, I continue to be amazed - this is the smoothest the car has ever felt. In a big way. I can't wait to really open this thing up and get it up to some triple digit speeds. I ran it up to ~80 mph just cracking the throttle and going through the gears. I think it is just years of refinement paying off. When I had my old single disk with a sprung hub, I still had the Samberg OEM diff mount and lots of driveshaft issues. There've been many incremental improvements. The engine seems smoother than my last one, the clutch is a world better, fixing the driveline lateral alignment, and road force balancing the wheels and tires all were major contributors.
After YEARS and multiple sets of gears, swapping to Ford Racing 3.73's finally fixed my gear whine issues. Different manufacturers, REM polishing - nothing prevented the gear howl with 3.90's. I know I for sure had two sets of 3.90's...maybe 3.
The car sounds really really good - it is surprisingly a lot quieter than the 402, which is odd. This LS7 is more cubes and has more overlap, but is way less rowdy sounding. Makes me think the cam might need to be a little bigger
The goal was to make it a better street car so I can't sabotage myself unless it really doesn't run how I want haha. I always have the big motor to throw in later.
Left to do is just really simple stuff:
I/O module wiring
Tuck the wiring inside and finish install the ECU
Reinstall all the interior and mount the Holley screen
Clutch adjustment
Fit the hood
Alignment appointment
Tune, break-in, fluid flush and dyno appointment
Professional paint correction and cermic coat if the paint looks good enough to justify it
Less critical:
I have a new map pocket to install
Need a new stereo and speakers
Oil cooler desperately needed
I'm really considering swapping to a BTR Trinity to get rid of the awful noise from this sheet metal unit, but will dyno first to make sure I like the powerband
Finish the 3d printed intake duct project
I want a skidplate. My oil pan gets scrapes, and its been punctured once hitting a giant rock
Finish my Porsche BBK project I started ages ago
