Front harness tuck is complete. There is a sticky in the electronics section (yes, ANOTHER sticky) if you want more details on that part.
Here is what is left visible of the entire front harness:
MUCH better.
Fuel system is also done, minus installing the in-tank Walbro:
[smg id=2189]
Everything can be removed with a quick connect release tool. No clamps need be removed. All clamped rubber hoses are positively retained with barbs.
[smg id=2190]
[smg id=2191]
For those curious, the filter is for a "1990 Chevy Celebrity" with MPFI. Cheap part, commonly available and included the short double quick connect line in the above picture.
In other news, the oil pressure sender (FC), water temp sender (FC), coil bracket and ignition module were MIA, so those are being ordered, and the slave cylinder was broken so I'll pick one of those up tomorrow. I'm planning to have the electrical system down and the dash back in tomorrow. Hopefully I'll also have the clutch bled, and all the non-engine electronics ready for testing. Next up after that is the new gauge tweaks, exhaust system, cooling bleeding, fluid and bolt check, then test drive.
