March 17, 2025, 11:07:52 PM
Author Topic: Darth Viper's LT1/FC Build  (Read 44243 times)
Offline mpcv2000
Re: Darth Viper's LT1/FC Build
« Reply #30 on: September 29, 2010, 07:09:28 PM »
Good to see another LT1 among the no-soul community.
+1   :cheers:
Martin !
« Reply #31 on: September 29, 2010, 10:16:39 PM »
Some more progress on the car today.
Pulled the dash, ran the engine harness into the interior, and cut the sheetmetal for the radiator.
Harness run:
[smg id=2112]
[smg id=2113]
Sheet metal trimmed back for the radiator, and primed:
[smg id=2114]
[smg id=2115]
[smg id=2116]
Dash, blower motor, and A/C evaporator pulled, harness run into interior, prepping to do the engine bay tuck (and documentation for it):
[smg id=2117]
« Reply #32 on: September 30, 2010, 10:31:43 AM »
A bit of documentation:
For the LT1 steam tube (this would also work for an LS1 steam tube, FWIW) I'm going to be using an inline adapter from Jegs.   Part no: JEGS 51155
This has a 1/4 NPT threaded port that a barb can be installed in.   It will be installed in the upper radiator hose.  It's also cheaper than the JTR or other options I've seen by about 15-20 bucks.
I'll post up when I figure out part numbers for the radiator and heater hoses also.
Offline theantirotor
« Reply #33 on: September 30, 2010, 01:23:38 PM »
what rad are you going to use?  jtr?
:bacon:
Offline mpcv2000
« Reply #34 on: September 30, 2010, 02:02:07 PM »
The top one  ( right side ) is the one from a 1994 Z28 Camaro 5.7L.
I just replaced mine . ;)
Martin !
« Reply #35 on: September 30, 2010, 02:05:13 PM »
No, it's just an eBay special.  All aluminum, 3" core, something like 24" wide by 18" tall.    Should fit the Taurus fan well.  It's narrow enough to fit without hacking all the sheetmetal out like I've had to with 27" wide units.
Sweet.   I have a 1994-96 Camaro radiator that came with the engine/trans and has the hoses attached, hopefully I can make at least one of them work.   :)   Thanks for the tip.
Offline RX7V8Builder
« Reply #36 on: September 30, 2010, 03:20:09 PM »
I used both radiator hoses off a 1996 Camaro.  The pass side was direct fit and the driver side i had to trim to shorten it a bit.
It will depend on the location of the radiator connections .
Here is a picture of the ones I got from Rock Auto with their numbers
Quote
LT1 water pump connections are 1 1/4".  The Jegs adapter you plan to use is 1 1/2"
'87 Base Model FC
8.8 IRS
Ricardo
« Reply #37 on: September 30, 2010, 03:30:33 PM »
Quote
Yeah, the hose will stretch just fine, done it before.   Just soak it in some hot water for a couple minutes first.   :)
Thanks for the tip on the hoses, I have both of those in the garage, so hopefully I can follow your lead on that (as I am on several parts of this build. ;)).
Offline therotaryrocket
« Reply #38 on: September 30, 2010, 06:38:24 PM »
sweet build, I'm watching this build for my own, pretty much the same setup, but somehow, I doubt my wiring is gonna be that purdy. So I'm thinking of a 23" wide radiator now that you mention how it's easier to mount and all. So for EGR block off, do you just cut some block off plates out of sheet metal or something? then the steam vent, i still don't even really get what that's for? is it like an air bleeder valve?
that red intake manifold is pretty pimp, it is kinda Ferrari like.
1987 Mazda RX-7 Turbo II powered by a 1994 Camaro LT1 and T56. :)
Offline clocker
« Reply #39 on: September 30, 2010, 08:48:50 PM »
The LT series engines have a reverse flow cooling system.
It was such an efficient and groundbreaking arrangement that GM dumped it after 5 years.
Basically, the coolant flows first through the heads and then down into the block.
The rear of the heads tend to run hotter and create steam pockets which screws up the entire flowpath, so GM introduced "steam vents" that vent back into the loop (typically to the AST) in an attempt to solve the issue.
« Reply #40 on: September 30, 2010, 10:58:19 PM »
Pretty wiring is my specialty.  ;)
FWIW, the LS1 also has steam vents.     Partially because of the dry intake manifold in that case.
« Reply #41 on: October 04, 2010, 10:49:30 PM »
Some more updates.    Radiator is in, paint is touched up, upper radiator hose and heater hoses in place.
[smg id=2167]
[smg id=2169]
[smg id=2168]
Touched up paint.   The flash washed it out a bit, it actually matches the stock paint very well.
[smg id=2170]
[smg id=2171]
Lower radiator mount:
[smg id=2173]
[smg id=2172]
« Last Edit: October 04, 2010, 10:51:06 PM by digitalsolo »
Offline Defenistrator
« Reply #42 on: October 05, 2010, 01:14:01 AM »
Nice.  What is this "ebay special" radiator and how much does one like that set you back?  Working on low funds, some OEM type rad that can fit close enough would be great for me.
« Reply #43 on: October 05, 2010, 04:32:31 AM »
Defenistrator, I'm thinking the ebay special is probably $140-150 shipped whereas you might get a stock radiator from some car to work, but new it'll be probably at least $100, and I read that those aluminum ebay radiators cool 4-5 times better, you know it gets pretty hot sometimes here in NC.
Did you mention the dimensions on the radiator?
Offline Darth Viper
« Reply #44 on: October 05, 2010, 08:03:05 AM »
Radiator ran me 142 dollars shipped.
Description is: 27"X19" ALUMINUM RADIATOR EXTREME DUTY HC-6003-RAD
http://motors.shop.ebay.com/__?_from=R40&_trksid=m39&_nkw=27%22X19%22+ALUMINUM+RADIATOR+EXTREME+DUTY+HC-6003-RAD
Boost Evangelist
"rotary's are like boats, awesome things for your friends to own..."
See me for all of your nuclear power plant needs.
