Thanks Charlie. I may try that out to sanity check this setup. All I am running for sway bars is an RB front bar. I was running 500/350 before (with different struts though) and the car felt better and was faster with the new setup and stiffer springs. I know that is apples to oranges, but just saying. The tire wear is more consistent now as well. To date, the stiffer I have went in front, the better the car has become. I did go too stiff in the rear and dropped the spring back down to 400.
I have a set of 500# springs already. I would just need to buy a set of 300 lb springs for the rear.
As an aside, the other FC guys here seem to be going stiffer with their spring rates (towards what I'm running).
I did not get to try this setup on a short, technical track this season, and still have a question if it will be too stiff. I think the car will be ok, but we will see. The Streets of Willow track is bumpy in sections.
