March 17, 2025, 11:18:11 PM
Author Topic: LOF's LS1 FC track car build  (Read 316221 times)
« Reply #1155 on: August 04, 2019, 11:47:19 PM »
That looks really, really good!    Nice work on the touchups!
« Reply #1156 on: August 05, 2019, 05:04:26 PM »
Thanks guys. Here are a couple pictures of the car out of the garage.
[attachimg=1]
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
« Reply #1157 on: August 05, 2019, 09:18:26 PM »
Looks AWESOME!!!
That settles it, this is the color for my Pro-Challenge Mustang.  :bacon:
I'm also going to add a pair of LeMans stripes down the center.  Do you think white or black stripes would look better?
« Reply #1158 on: August 05, 2019, 10:02:22 PM »
Looks AWESOME!!!
Thanks!
I think black looks better. I was/am considering some black fender stripes like the Camaro/Corvettes have.
I thought about painting the taillights orange too, but like the satin black..kind of a throwback to the big block GM muscle cars. A 5.7 is a big block compared to a 1.3 right? :)
Offline AKINA FC
« Reply #1159 on: August 06, 2019, 01:35:49 PM »
Turned out great LOF, nice work.  :cheers:
« Reply #1160 on: August 06, 2019, 03:45:53 PM »
Looks AWESOME!!!
Thanks!
Thanks, I was leaning towards black and Orange anyway.  Should look good with basic black wheels too.
I hope I can find some light and fairly cheap 15x8 alloys for it, but could always go with steel stock car style wheels as well.
« Reply #1161 on: August 06, 2019, 04:40:31 PM »
Thanks!!
« Reply #1162 on: August 06, 2019, 09:27:25 PM »
Looks great Ash.  I think some fender stripes could be great.  Like this?
« Reply #1163 on: February 06, 2020, 04:48:23 PM »
Final start up last week with the old T56.
http://youtu.be/bnPFEk2HoYc
Got the new T56 Magnum F ready to go in tomorrow. I had to shorten the driveshaft 1 1/8 inches. This was due to needing a different 2 piece trans yoke for the 8.8 conversion. I am running 1310 U joints and the small mustang pinion yoke. Those that went 1350 joints from the start, probably can reuse their driveshaft as is.
Since the Magnums are all 30 spline, you need a different trans yoke if you run 1310 joints. Inland Empire Driveline makes a really nice forged 2 piece 30 spline yoke for 1350 U joints. This thing is much bigger than my old iron 1310 yoke, and weighs about the same. part number is SY-C6-1350Q
From there I needed a 1350 to 1310 conversion joint. After getting the conversion U joint home it was obvious I needed to shorten the driveshaft as the new forged yoke is physically longer than the old one.
Anyway, The trans is prepped, and I will throw it in tomorrow. One nice thing about the Magnum F - I was not able to wire up reverse lights before, as the plug on the trans was nearly against the trans tunnel. The Magnum F has a wired dongle instead of a plug sticking directly out of the trans, so I can wire up reverse lights if I wanted.
« Last Edit: February 06, 2020, 04:54:02 PM by largeorangefont »
« Reply #1164 on: February 06, 2020, 05:05:46 PM »
Sweet man!  I keep seeing these things around and it has me thinking about swapping even though I already have a magnum.  I figure I could get most of my money back selling the magnum used.
The magnum is a sweet piece.  Way better both performance wise and quality of life.  Loves to be shifted fast.
« Reply #1165 on: February 06, 2020, 08:17:39 PM »
Yea the thing shifts like butter sitting dry on the ground with no stick lol. The stick I have won’t work with the Tremec shifter that came with it, so I am putting my OE Hurst SS/WS6 shifter on it. Still feels like it shifts great, the centering spring on my Hurst shifter is way stiffer than the Tremec shifter it came with. I’m used to the Hurst shifter and don’t think I ever missed a shift with it, so it should work fine.
Still a little tempted to just make the new Tremec shifter work with my stick, as it will be better for NVH, but who am I kidding, like I’d even notice in this thing.
I’ll have some pics tomorrow as the suffering begins getting this back in the car.
I’m just gonna put Redline D4 in it straight away.. any objections?
« Reply #1166 on: February 07, 2020, 12:11:56 AM »
So Mark talks about a big change after break in. I didn’t notice any difference from mile 1 to 1000 and I used dino oil for break in and put redline in it after.
Non-synthetic is supposed to be better for break in, but all OEM’s are factory fill for 100k miles these days so I’m sure you’ll be fine.
« Reply #1167 on: February 07, 2020, 01:25:24 AM »
What oil did you use for break in - synchromesh? I may do that.
Offline shainiac
« Reply #1168 on: February 07, 2020, 07:52:31 AM »
The Inland Empire yoke is the nice piece. I'm using the same one and it makes removing the driveshaft easy. I did receive an out-of-spec unit first. The OD of the yoke was too large and was actually contacting the tailshaft bushing. I contacted Inland Empire and they got me a new one right away. If you haven't already, you may want to test fit the yoke to make sure it fits well.
BMW DCT Swap, Ronin 8.8" IRS
« Reply #1169 on: February 07, 2020, 09:44:46 AM »
This one fits nicely, thanks for the heads up.
