March 17, 2025, 01:15:25 AM
Author Topic: LOF's LS1 FC track car build  (Read 316122 times)
Offline eage8
« Reply #1065 on: July 05, 2016, 05:01:35 PM »
how do those attach?
'89 RX-7 TurboII - Ronin Widebody and Ford 8.8 - 13B lolz
'89 Corolla SR5 - 4A-GE 20 Valve 6 speed swap Megasquirt
'01 Impreza 2.5RS - Daily driver/rally-x car
'81 BMW R65
« Reply #1066 on: July 05, 2016, 05:34:05 PM »
You drill 3/16" holes in the existing metal pedal base. It comes with stainless hardware and lock nuts to attach them. I really just wanted the gas pedal cover only, but now that I have them the rest of the covers are pretty nice. The clutch and brake covers are larger than stock as well.
I made the gas pedal cover adjustable. I have 2 sets of holes for it if I want the gas pedal even closer when I get to the track. In my mountain road testing it felt pretty good where it is though.
« Reply #1067 on: August 30, 2016, 02:12:23 PM »
I installed the matching dead pedal
[smg id=8497 type=preview align=center caption="image"]
« Reply #1068 on: August 30, 2016, 02:22:52 PM »
Looks good. How hot does your floor/tunnel get while your on track?
« Reply #1069 on: August 30, 2016, 02:28:48 PM »
Well guys I had some more fun with wheels today. I got a 17X10.5 to fit all around, so I am going to try these on my next set of tires still running 275s all around. This was a test setup so ill order it all up soon.
« Last Edit: August 30, 2016, 02:36:00 PM by largeorangefont »
« Reply #1070 on: August 30, 2016, 02:35:09 PM »
It is notably hotter where the see the tar chipped off by the gas pedal. I can hold my hand on the trans tunnel with the tar. Without it it is uncomfortable to hold my hand on it or I cant after a track session. It is not going to blister you or anything, it is just hot.
I have underside of the trans tunnel lined with heat shield from the firewall to the shifter. It made the whole deal live able on track.
Offline Supe
« Reply #1071 on: August 30, 2016, 06:40:40 PM »
Any spacers needed to clear front or rear?  Mine are still sitting in the corner of my dining room...
« Reply #1072 on: August 30, 2016, 07:03:57 PM »
3mm spacer in rear to give the tire room around the rear trailing arm. 8mm spacer in front. In the pictures there is only 3mm of spacer in the front.
with the 8/3 spacers the tire is in the same position it was with the smaller wheels.
Thanks for the info last week!
« Last Edit: August 30, 2016, 10:04:15 PM by largeorangefont »
Offline Supe
« Reply #1073 on: August 30, 2016, 09:50:00 PM »
I should be pretty close then, thanks.
Offline 1320king
« Reply #1074 on: August 31, 2016, 11:15:21 AM »
how hard was it to pull the rear fenders like that?
« Reply #1075 on: August 31, 2016, 11:41:24 AM »
I used a baseball bat originally to gain 1/4 inch. To get it where it is now Joel came over with his Eastwood fender roller.
Offline AKINA FC
« Reply #1076 on: August 31, 2016, 12:57:38 PM »
That looks great Ash! Its amazing that 275 doesn't look stretched at all on a 10.5  :cheers:
« Reply #1077 on: August 31, 2016, 03:58:24 PM »
These tires are giant. Time to get a fresh coat of paint on this thing and some aero to see what it will do.
Offline AKINA FC
« Reply #1078 on: August 31, 2016, 06:12:56 PM »
You had me at fresh paint  :cheers:
« Reply #1079 on: August 31, 2016, 06:40:38 PM »
My paint and body hookup is retired, so I am on his schedule. He is going to call me on some random day sad say "Hey, let's shoot that thing!"
