March 18, 2025, 05:54:11 AM
Author Topic: LOF's LS1 FC track car build  (Read 316252 times)
Offline Bowtie7
« Reply #1005 on: July 04, 2015, 12:53:58 PM »
Thanks Charlie. I may try that out to sanity check this setup. All I am running for sway bars is an RB front bar. I was running 500/350 before (with different struts though) and the car felt better and was faster with the new setup and stiffer springs. I know that is apples to oranges, but just saying. The tire wear is more consistent now as well. To date, the stiffer I have went in front, the better the car has become. I did go too stiff in the rear and dropped the spring back down to 400.
I have a set of 500# springs already. I would just need to buy a set of 300 lb springs for the rear.
As an aside, the other FC guys here seem to be going stiffer with their spring rates (towards what I'm running).
I did not get to try this setup on a short, technical track this season, and still have a question if it will be too stiff. I think the car will be ok, but we will see. The Streets of Willow track is bumpy in sections.
I bet the RB front bar is too soft and the stiff front springs are compensating. On square setup I don't run a rear bar but with staggered I run a stock rear bar and it seems to balance the car nicely. I found that a .250 wall Speedway front bar works really well on either setup.
I do love what I do!
« Reply #1006 on: July 04, 2015, 01:19:10 PM »
Yes Charlie, I believe you are right. I would like to go to a speedway front bar setup to drop a couple pounds and get some more adjustment.
Do you mount your speedway bars in the stock locatio. or somewhere else? The Mazdatrix car ran it on top of the frame rail.
There appears to be enough to room to run it in the stock area similar to Joel's speedway bar.
Offline Bowtie7
« Reply #1007 on: July 05, 2015, 11:22:54 AM »
Reinforced stock location
Offline kartermdb
« Reply #1008 on: July 05, 2015, 11:09:46 PM »
1 1/4 OD front bar? How long is the bar? How long of an arm?  I'm currently running a solid 1 1/4" bar, 37" long with a 7' arm.
I wish I could compare more of my front end setup to what you guys are running.
Offline Bowtie7
« Reply #1009 on: July 06, 2015, 08:20:27 AM »
Ours is 36" long tubular bar, .250 wall, 11"arm. Not sure how you are able to make a 7' arm fit :D
« Reply #1010 on: July 06, 2015, 12:43:50 PM »
I am sure the SLA front suspension on his car has something to do with it.
« Reply #1011 on: July 10, 2015, 01:23:42 PM »
I got my scales and weighed the car today. The car is nearly full of fuel (only a gallon or two down), so I was pleasantly surprised with 2686#. An empty tank would put me right at 2600 lbs. This is with 17X9.5 wheels and 275 tires, fire extinguisher, camera mount, 2 quart Accusump, 9.5 quarts of oil, larger front Mandeville brakes, dual 3 inch exhaust..  Everything the car gets driven with.
 I can easily get 60-80 lbs off the car. 30lbs of it is the sunroof, and I can get another 30 lbs off by going to a lexan rear hatch window. The car still has 5-10 lbs of extra wiring in it, and all the sound deadening tar in the interior.
I have yet to add the splitter and rear wing, which will probably be around 40 lbs combined.
Total weight, wet with no driver.
Weight on the front, no driver.
Total weight with driver.
Total weight on the front with driver.
« Last Edit: July 10, 2015, 03:59:13 PM by largeorangefont »
Offline atli126
« Reply #1012 on: July 10, 2015, 02:13:36 PM »
nice man my street car is 51% 49% and right at 3200 and thats 5.3 iron block, with ac, me 160# sound deadening etc etc
-Bret
« Reply #1013 on: July 10, 2015, 02:40:49 PM »
Nice. That interior and sound deadening accounted for the difference in weight distribution between us.
Offline scuter83
« Reply #1014 on: July 10, 2015, 03:20:09 PM »
Its funny to see adding a driver put more weight on the rear of the car than the front, ha.  ~90lbs of your ~220lbs goes to the front and the rest to the rear according to your numbers.
« Reply #1015 on: July 10, 2015, 06:29:49 PM »
Well you sit pretty far behind the front wheels, so that makes sense that youd pick up most of it in the rear.
I'm actually surprised how close the cross weights are. I measured and set my droop, shock length, preload and endlinks, but I didn't think I'd net a .1% difference in cross weight in the first shot!
That all goes to hell when I get in the car, but now that I have the scales I can adjust for a driver accurately.
« Last Edit: July 11, 2015, 10:54:53 AM by largeorangefont »
Offline 1320king
« Reply #1016 on: July 10, 2015, 07:56:12 PM »
still have the bumper beams?
« Reply #1017 on: July 10, 2015, 08:18:47 PM »
I have the rear stock beam. In front I have a fabricated crash bar. it was not much lighter than stock actually.
Offline FC3S Murray
« Reply #1018 on: July 11, 2015, 01:04:28 AM »
I'm telling you Ash, these S4 FC's seem to be lighter after a lsx swap then the S5's do lol. Mine is 2740 wet no driver with all kinds of creature comforts(old ass boston speakers and fosgate sub).
I am really hoping you do a lexan rear hatch and then sell copies of it to members here :). That alone will save you some weight or at least make the soon to be installed areo not any real extra added weight from where you are at right now.
SRM Performance Tuning LLC
Offline Bowtie7
« Reply #1019 on: July 11, 2015, 04:26:41 PM »
No cage, right? That weight is really nice and light.
