March 16, 2025, 04:26:26 PM
Author Topic: My 4.3 vortec 84 FB  (Read 127828 times)
Re: My 4.3 vortec 84 FB
« Reply #375 on: January 25, 2021, 02:50:40 PM »
FWIW I prefer PAC over Comp for springs.  I do like Comp's cams though
Offline cholmes
« Reply #376 on: January 25, 2021, 02:52:19 PM »
Looking forward to spring pic, as I have the same ones.
Offline rk970
« Reply #377 on: February 05, 2021, 12:56:42 PM »
comp 26918. '
and the best one.
Good quality imported work right there..
Offline cholmes
« Reply #378 on: February 05, 2021, 01:15:19 PM »
Hmm, wonder if their new high dollar conical springs have a similar problem.
Offline rk970
« Reply #379 on: April 23, 2021, 08:17:45 PM »
Oh noes, the slave cylinder be done.. It was weeping, so I was going to order a rebuild kit.  CNC (Chuck Neal Corp) is no longer in business so I ordered a EMPI unit. Good thing I took it apart as it had some trash in it.  Rehoned it with 600 ball hone and polished the shaft with 2500.
Anyhoo.. Doing a oil/filter change, the oil level dropped 1/16" in 2000miles so the oil burning it fixed  :)  changing the diff oil and rotating the tires.  Then it gets a wash, unbelievable how dirty rubber dust makes a car.
« Reply #380 on: April 24, 2021, 08:35:55 AM »
Oil usage fixed!   Woohooo!!!!
« Reply #381 on: April 26, 2021, 10:43:50 AM »
Looking great!  I am jealous you have driven your car so much more than me
« Reply #382 on: April 27, 2021, 03:27:04 PM »
Nice work sticking with it!  Crazy on the spring pressures, I am clueless there and would have been chasing other issues for high RPM and no power.  Great job!
Offline rk970
« Reply #383 on: May 12, 2021, 06:15:40 PM »
I built a weight to attach the the tailshaft of the trans to reduce some of the vibes (v6 engines are not the smoothest)
and I promptly removed it.. it helped above 3500rpm and below 1900 it was like driving on a cobble stone road.  So the 34 year old rubber mazda mounts appear to be way to darn stiff.. I got some ranger rover mounts on order since they are the same thickness and hopefully a little softer..
The great news is I drove out to Walla Walla from Whidbey Island 368 miles one way with no traffic ( I left at 4:30am) and averaged 64mph with 28mpg and on some of the long up hill stretches on hwy 82 I was bombing along at 120+.   Over the 736 miles (best I can measure) the oil level dropped ~.040-.050"..
On that trip I got a 7hr data log and I was able to get my baro correction curve and the air temp correction curve dialed in.  Baro ranged from 101.8 to 80.2 and air temp 37° to 114°F on the data log
I took a chance and ordered seat upholstery form Lseat. I got a tracking number and they should be here this friday. All black leather with perforated center panels. I will attempt to make a Utube video of the whole seat rebuild process.
The rear bearing of the alternator blew up again, I took the rotor out and had it rebalanced for $20 and some beer.  It was not balanced very well, cuse China.
 :bacon:
« Last Edit: May 12, 2021, 08:19:54 PM by rk970 »
Offline rk970
« Reply #384 on: May 17, 2021, 08:08:51 PM »
Wish me some luck...
« Reply #385 on: May 17, 2021, 08:25:52 PM »
I’ve played that game!
It’a not fun.  At all.
Offline rk970
« Reply #386 on: May 19, 2021, 08:52:14 PM »
Got the passenger seat apart.  The listing wires were rusted away (the wire in the cover that gets hog ringed to the seat frame) and I am going to use 3/32 welding rod to replace them.  I think someone was drinking to much Sake as one the listing wires had 20 (yes 20) hog rings on it attached to nothing.
Offline rk970
« Reply #387 on: May 21, 2021, 08:22:19 PM »
ohh that was a Mofo
« Reply #388 on: May 24, 2021, 08:34:55 AM »
It looks good! the suffering was well worth it
Offline rk970
« Reply #389 on: July 13, 2021, 01:35:38 AM »
I feel like the seat upholstery was a success.
In other news getting the acceleration enrichment has been changeling.  I had to  blend tps/map dot,.  2500rpm in 2nd and giving the throttle a quick jab results in a nice amount of wheel spin..   :drive:
