Also, since this is the how to thread I wanted to point out an additional item.
For the Wiper Motor harness that was part of the engine harness. If you forget to cut this harness off before disposing/selling the engine harness I want to point out that this is a pretty typical 6-pin power connector that is used in other location on the chassis harness. As I removed all dead wiring from the emissions harness i found that I had three harness that all work for this application. The one I ended up using is the Starter Cut Relay harness but i believe the AAS harness will also work if you installed aftermarket suspension this will be available to you as well.
All you need to do is take one of the other 6-pin harnesses no longer in use and modify the pin-out for the Wiper Motor.
