March 18, 2025, 05:24:34 PM
Author Topic: How To: "Tuck" the front chassis harness on an FC/FC Front Harness ID  (Read 65148 times)
Re: How To: "Tuck" the front chassis harness on an FC/FC Front Harness ID
« Reply #30 on: March 22, 2012, 10:52:24 PM »
I'm super busy at the moment.   Part of the reason I left it vague was so that people wouldn't get in over their heads.
Next time my car is in the air I'll get some pictures of the routing through the fender.   :)
Offline Sho Amo
« Reply #31 on: March 22, 2012, 11:34:14 PM »
I kinda got that feeling while reading some of the responses. I think im going to just 'dive' into it tomorrow.
Im pretty confident in my skills, but Ive never done anything this drastic (wiring related).
[Sold] '90 GTU LS1/t56
Offline Solo
« Reply #32 on: March 23, 2012, 03:45:36 AM »
Next up is what circuits you can pull out and how, what to extend and how/where to extend it to, and how to route the harness through the fender out of the way.
Would you mind updating this Blake? Im in the middle of wiring and would love to simplify my harness.
+1
Offline Sho Amo
« Reply #33 on: March 24, 2012, 12:06:53 AM »
It turns out mine is going to be pretty straight forward. I have no power locks, windows, sunroof, abs, fog lights, and the simple power steering setup. All I really needed in the front is headlight retractors, headlights, relays, and turn signals. Once I have the dash back in with the car actually running and all the hvac worked out, ill tuck the harness. I just want to be able to test wires while im working, which I cant do right now.
Offline quick.msp
« Reply #34 on: April 22, 2012, 08:07:24 PM »
Is there a similar thread like this that deals with the harness inside the car?
'93 bb Touring LS3
Offline badassf4i
« Reply #35 on: April 23, 2012, 12:43:52 PM »
i would love to see a detailed writeup line this for a fd. nothing better then a clean engine bay
Offline Grumpy
« Reply #36 on: April 27, 2012, 02:41:02 PM »
Nice thread so when I get up off my ass I can do something with the rats nest I have in the car now !! 8)
Dan
AKA "Sleeper6"
9.999 @ 135.96
Buick GN V6 Turbo
8.8 Ford rear end. 308 gear.
200 R4 with a LU converter
Drag Radials
3324#s
Offline N2v8fcs
« Reply #37 on: June 06, 2012, 10:39:59 AM »
what do you do for the hood release?
Is it just routed along with the wiring ?
:drive:
« Reply #38 on: June 06, 2012, 12:57:19 PM »
I don't have a hood release on my car.
Offline DavidPHumes
« Reply #39 on: August 06, 2012, 12:43:10 AM »
I did my tuck 6 or so months back and am SUPER happy with it. I just got to testing everything out (yeah I know I have a little too much faith in my work lol) and everything works EXCEPT my headlights. What else to I need to check before digging into my wiring? The relay is connected (and you can hear it click when the head light switch is turned to "on"), the fuse looks good... I don't know what else it could be. Do I need to have any other relays connected other than the 1 for the headlights? I really don't suspect wiring to be the case as everything was soldered, heat shrinked and then taped (though I'm not the best at soldering I guess...).
« Reply #40 on: August 06, 2012, 09:37:55 AM »
I'd check out power at the switch, that's usually the issue.  That and verify continuity through the relay when it's on.
Offline jparker7
« Reply #41 on: August 11, 2012, 09:58:18 PM »
Did anyone ever do this to an FD.  ID really like it done to my car and mine has no interior or front clip so it would be pretty easy.
Offline DavidPHumes
« Reply #42 on: August 16, 2012, 06:17:12 PM »
You should have told me to check my headlight switch to make sure I didn't have my high beams (that I don't have) on. Oops... working great now  :D
if0rg0t
  • Guest
« Reply #43 on: September 29, 2012, 03:01:53 PM »
So I'm trying to thin out the wiring harness on my FC. So far I've identified all the connectors I need. I could use a little help in how to get the harness out of the engine bay and into the car. In your pictures, it seems like you've managed to bring the harness into the car without cutting the connectors yet. Or do I need to cut the connectors, get rid of the loom/tape, and pull the wires from inside the car, and then remove the grommet? Does the grommet come out last, after the wires have been pulled inside, or do I just need to push it in from the engine bay side with a dowel/screwdriver?
I managed to remove the dash, and steering column to make some room. Also unplugged the CPU and moved the wiring out of the way.
Are the front harness wires hard wired into the fuse box, or is there a connector on the back? I unbolted the fuse box, but the wiring is so tight in there that it can barely budge. Any advice?
[attach=1]
Also, do I have to undo the plastic formers?
[attach=2]
if0rg0t
  • Guest
« Reply #44 on: September 29, 2012, 03:17:43 PM »
I jammed my hand back there behind the fuse box and it seems that it is fastened in some manner. I removed the 10mm nut on the bottom of the fuse box. Is there another that I can't see, or maybe a plastic clip?
Am I even correct in assuming that I need to take the fuse box out in order to thin out the front harness? Cuz it sure looks like it's in the thick of things there in the corner, and having access to it would help .. ?
