If you're already going to spend money on crank, rods, pistons, check out the OEM GenV L8T crank. It's from the 6.6L gas engine for the newer HD trucks.
With a 3.860" stroke and a 4.0" bore, it works out to 388CID. It's an oddball stroke, but IIRC, there are off the shelf pistons for 4" stroke that can work with a 6.200" rod.
It's supposed to be a badass crank, though. It's center-counterweighted, which is usually only found on $$$ stuff, and forged steel from the factory. It also uses 8 bolt flywheel, so you may have to replace yours. The Gen2 CTS-V stuff is 8 bolt also, so there are some Gen4 options. They're $820 on BTR and Scoggins' sites, so not cheap cheap, but a nicer piece than most aftermarket budget cranks.
