Good evening, I have spent the better part of a weeks worth of free time trying to find the other end of a cut wire goes.
The Red with black spots, main headlight power wire that comes from the main headlight fuse. Comes to a 4 wire split: 1 from the fuse, 2 go to the he headlight relay connector. Then a 4th is cut and looks like it would go back down the harness towards the interior of the car but there is no wire there just the cut end going into the splice.
I cannot find a cut red wire end anywhere else in the rest of the front/dash harness. I pulled and stripped the entire thing looking.
In the 86-88 FSM on rotaryheads it shows only three red wires at that junction. So I am a bit lost as to where this 4th wire goes.
Thank you for any help. I've attached a photo of the wire that hopefully works.
