Man its nice to buy a car with a FULL updated wiring manual!
I have been studying that and the X23 connector in the rear close to the spare tire and pass taillight, I figured out
@halfspec ran switched power through that connector repurposing pins that he removed from the power antenna. That clued me into disconnecting that connector it would allow me to test the harness I showed in the above post. Sure enough I disconnected that and the fuse didn't blow. So now I know the short is in that other harness going from this location to the Racelogic and Radar power wire.
The weird part is I expected my Wideband to power up now because I didn't see any connections for that circuit that would run through this connector. It did NOT, so I will continue to track that down. I attached that picture and now with the White plug disconnected in the lower right corner (X23) it no longer blows fuses when switched on so those wires and relay should be good.
Fun stuff! Couldn't imagine trying to work on a PO wired car without this manual!
Here is a link to his if anyone is curious, crazy amount of work!!
https://www.halfspec.com/downloads/rx7/Halfspec_FSM.pdf
