Hi All,
I've recently picked up an LS1/t56 swapped FD. The project was started 10 plus years ago but never finished. The car is tacky but complete, the engine swap wiring was a disaster so I am cleaning that up.
My problem is I can't find a wire that is 12v while cranking and in run position. So while cranking the PCM is getting no power. I did connect the pcm ignition wire to constant 12v and the car starts right up, but is have to pull the jumper to turn the car off.
I'm using the starter wire in the left side engine connector (x11 ) to trigger the starter and the ignition wire (run) in the (x11) connector to trigger my switched power relay. The problem is the ignition wire has no power when cranking so my PCM isn't doing it's thing. Is the ignition wire in the x11 connector supposed to have 12v when cranking? I tested it and it does not. I also looked at the black wire in the x-5 connector, same issue.
Where is the start/run wire?
I've searched through the forums and googled, using Granny diagram as a reference, having no luck.
Help?
