Is your 84 a GSL-SE? If so, it has 5 lug wheels, put on the wheels / tires you want to run for a test fit. Adjust the 8.8 width as needed.
Any reason not to match up the stock rear-end width? A 235 shouldn't be a huge challenge, tire wise, but your wheel offset/width has more to do with axle layout.
