March 31, 2025, 04:46:48 PM
Author Topic: Reduced prices parting out build many LS parts  (Read 1371 times)
Offline fdrx7
« on: April 27, 2024, 09:49:26 PM »
Updates prices and Pics
https://www.facebook.com/groups/185003211545794/permalink/7589344327778275/?mibextid=W9rl1R
Prices do not include shipping. Thanks for looking.
Less than 1000 miles Nick Williams 102mm throttle body rear was slightly shaved for clearance sold
New Brian Tooley Racing VVT delete kit for LS includes
TIMING COVER:
1 X CHEVROLET PERFORMANCE TIMING COVER
LS1/LS2/LS3/LS6-12633906
CAM BOLTS FOR 3 BOLT CONVERSION:
1 x ARP LSX CAM BOLT KIT 134-1003
CAM GEAR FOR 3 BOLT CONVERSION:
1 X CHEVROLET PERFORMANCE FOUR POLE CA GEAR - LS2/LS3 - 12586481
TIMING CHAIN DAMPER:
1 x CHEVROLET PERFORMANCE TIMING CHAIN DAMPENER - LS2/LS3 - 12588670
TIMING CHAIN:
1 x KATECH C5-R TIMING CHAIN - REPLACES HM068V-2 - 7636
WATER PUMP GASKETS:
2 × CHEVROLET PERFORMANCE WATER PUMPGASKET - LS - 12630223
CRANK BOLT:1 x ARP CRANKSHAFT BOLT - LS -234-2503. $350
Used Factory LS7 crank, titanium rods with ARP bolts and Weisco 4.130 pistons. 2 of the pistons have some small surface nicks on the edge but the crank and rods are good to go with no nicks or chips. $1300
New Mighty Mouse catch can for LS. Sold
Used matched LS1 ID 1000 injectors 1000 miles never ran with E85 $500
New C6 ZR1 injectors and pigtails sold
Used Meziere LS electric water pump with harness used 1000 miles. $350
New Chevrolet Performance Timing Sprocket # 12556582. Sold
New factory LS1 AC Delco alternator with mount $125
New Improved Racing crank scraper EGM -305 for 4.0 crank with clearance for ARP and aftermarket rods $125
Dyno time only MSD starter #5096 $175
New ATI Super Damper SerpentineSeries Harmonic Balancer NA application 10 % underdriven AT1917278 sold
New ATI Crankshaft Pin Drill Kit AT1918993 $75
New Tick Performance PAC 1207X .700" Lift Valve Spring Kit with Titanium Retainers for LS $225
New Set of 8 GM OEM Delco 12611424 Ignition Coils LS3 LSA LS7 12570616 and LS7 valve covers with bolts and gasket. Sold
New CHEVROLET PERFORMANCE REAR COVER - GEN III & IV - 12639250 and gasket $75
New Chevrolet Performance Lifter Valley Cover Chevy Small Block Gen III/IV LS Engines. Sold
New Hubbard racing ported GM high volume oil pump $80
New ARP Pro Series Cylinder Head Bolt Kits 134-3610 sold
New ARP pro series 11mm flywheel bolt kit 330-2802 $20
New ARP ARP Balancer Bolt 234-2504 for LS7 sold
New ARP Main Stud Kit 234-5608 sold
New MSD 8.5mm Super Conductor Spark Plug Wire Set 32813 and new TR6 NGK4177 spark plugs. $90
New Scoggin Dickey LS7 dry to wet sump conversion spacer. $20
New takeoff factory LS7 intake and fuel rail. $175
New Lingenfelter GT21 cam $176
GMPP Polished Valve Covers - Part# 19171502 - Includes gaskets, bolts and cap. These are tall so they will clear aftermarket lifters & big cam.MSD custom length wires - MSD cord & connectors. Work perfect, no misfires or issues.Coil relocation brackets (2) - Includes a couple different size spacers for coil size and mounting options. 4ft Coil extension harness (2)This setup was on an RX7 FD with the coils mounted up front directly below the headlights.$300
Sakebomb garage LHD aluminum foot plate new $120
Tilton master cylinder with speed bleeder for RX7 FD sold
New ST suspensions RX7 FD front and rear sway bar set with hardware $350 FYI due to size they are not cheap to ship!
I tried to take pictures of everything, but if you need anything additional, please let me know.
Athens GA 770-402-6611
Thanks,
Jon
« Last Edit: April 30, 2024, 02:23:34 PM by fdrx7 »
