Hi guys,
Trying to clean up some space in my garage after my last round of work. Please DM if you have any questions about these:
- Dakota Digital Universal Tachometer Signal Interfaces SGI-8E - $60
- Delphi front relay/fuse box - used by many members here and in GMPP kits, perfect for consolidating and cleaning up all of your engine bay electronics (see my post here). Brand new top and bottom case, includes 6 SPDT relays, fuses, locking clips and two metal mounting brackets. I also can include my old pre-terminated leads and all of the unused terminals along with their part numbers needed to populate this which takes out a HUGE amount of guesswork when doing this (see my previous post here for how it looks https://www.norotors.com/index.php?topic=27748.msg349167#msg349167) - $125
- Leash Electronics Dual 40amp relay board, potted and great for adding a few relays in your cabin without adding a bunch of bulk - $40
- "Fast style" OEM LS3 card MAF, brand new unused - $50
- Blue Sea 5028 6 position ATO/ATC fuse block https://www.bluesea.com/products/5028/ST_Blade_Fuse_Block_-_6_Circuits_with_Cover - $20
- Blue Sea 5046 8 position slim ATO/ATC fuse block https://www.bluesea.com/products/5046/ST_Blade_Compact_Fuse_Blocks_-_8_Circuits - $20
- Blue Sea 1733 Mini OLED DC Voltmeter - $25
