I feel I am decent at wiring but still a newb and can't quite wrap my head around Digital inputs on a stand alone. Specifically on the MaxxEcu Race version they list a ton of features under the digi inputs. Like AC compressor on, AC clutch off, 4 different ones for cruise control. On the physical wiring how do you do it with switches and to what inputs? It seems like the ECU would need a ton of inputs if you want to control cruise, AC, etc. I only see 4 dig inputs on the race ecu and 1 of those is speed. So its not a wire for input ratio do you use some sort or switch box? Or maybe I am over thinking it, originally I was thinking digital inputs are all the values available inside the ECU like MAP, TPS, etc etc.
I ran out of inputs on my Motec and sucked when I needed more but that was wire for input ratio of 1 so it was easy for me to understand and I never used any digital because I don't know what it is lol.
So just looking for a pragmatic example of how you used a lot of these with only a couple pins wired?? Thanks!!
Here is the Maxx digi input list:
-AC CLUTCH DISABLE
•AC REQUEST/IDLE UP
•ACTUATOR TARGET STATE
•ADVANCED WARNING SYSTEM, ENABLE
•ADVANCED WARNING SYSTEM, ENABLE CUT
•AFTER LAUNCH POWER LIMIT DISABLE
•ANGLE LOGGER
•ANTI-LAG ENABLE
•AUDI TRIGGER CAM SENSOR
•AUTO TRANSMISSION GEAR SELECTOR
•AUTO TRANSMISSION LOCKUP ENABLE
•AUTO TRANSMISSION MANUAL MODE SWITCH
•AUTO TRANSMISSION, ENABLE WOT RPM SHIFT
•AUTO TRANSMISSION, SWITCH TO 2ND SHIFT TABLE
•AVG FUEL CONSUMPTION RESET
•BMW BSD BUS 1 INPUT.
•BMW MS 43 STEERING WHEEL BUTTONS
•BOOST CONTROL ENABLE
•BOOST TARGET SWITCH
•BRAKE PEDAL/STOP LIGHT ACTIVE
•CAN, DISABLE ALL TX
•CHASSIS SPORT MODE
•CLUTCH SWITCH
•COUNTERS
•CRUISE CONTROL, ABORT
•CRUISE CONTROL, ACCELERATE
•CRUISE CONTROL, DECELERATE
•CRUISE CONTROL, RESUME
•CRUISE CONTROL, SET
•DIRECT ECU OUTPUT CONTROL
•DCT CLUTCHKICK/BURNOUT MODE
•DCT DRIVELOGIC DOWN
•DCT DRIVELOGIC UP
•DISABLE TRACTION CONTROL
•EGT POWER CUT, ENABLE
•ELECTRIC WATERPUMP OVERRIDE INPUT
•ENGINE RUNTIME+MAX RESET
•ERROR CODES, CLEAR ALL CODES
•ETHANOL SENSOR
•E-THROTTLE VOLVO BACKUP PEDAL POSITION (PWM)
•E-THROTTLE VOLVO MAIN AND BACKUP PEDAL POSITION (PWM)
•EXTERNAL LAMBDA 1, ERROR
•EXTERNAL LAMBDA 2, ERROR
•EXTERNAL LAMBDA 1, VALID
•EXTERNAL LAMBDA 2, VALID
•EXTRA FUEL TABLE X TABLE ACTIVATION SWITCH
•EXTRA IGNITION TABLE X TABLE ACTIVATION SWITCH
•EXTRA FUEL/IGN TABLE ACTIVATION SWITCH (ALL)
•FAN + ELECTRIC WATERPUMP OVERRIDE INPUT
•FAN OVERRIDE INPUT
•FUEL ADAPTATION, ENABLE ADAPTATION
•FUEL PUMP OVERRIDE
•IDLE CONTROL DISABLE
•IGNITION KEY
•LAUNCH CONTROL SWITCH, ENABLE STAGE
•LEAN POWER CUT, ENABLE
•LOGGING, RESET AND START NEW FILE
•LOGGING, RUN
•MDASH PAGE/RESET CEL (HOLD)
•NITROUS ENABLE SWITCH
•NITROUS PURGE
•NITROUS STAGE X ACTIVATE
•NITROUS TIMER RUN
•POWER MANAGEMENT SYSTEM DISABLE
•POWER MANAGEMENT SYSTEM ENABLE
•PULSE OUTPUT X TRIGGER INPUT
•PWM INPUT FREQUENCY+DUTY
•ROLLING LAUNCH CONTROL SWITCH
•RPM LIMIT, ENABLE GP LIMITER
•RPM LIMIT, USE SECONDARY LIMIT RPM
•RPM LIMIT, USE SECONDARY MODE
•SENT PROTOCOL INPUT
•SHIFTCUT
•SHIFTCUT ENABLE
•SPEED LIMIT X ENABLE/SET
•SPEED LIMIT RESET
•SPEEDSENSOR DRIVE SHAFT RPM
•SPEEDSENSOR TRANSMISSION INPUT SHAFT RPM
•SPEEDSENSOR WHEELSPEED FRONT/REAR RIGHT/LEFT
•STARTER MOTOR INPUT
•STOP ENGINE/PREVENT START
•THROTTLE BLIP ENABLE
•THROTTLE BLIP TRIGGER
•TIMER X START/STOP/RESET
•TRANSBRAKE BUMP/CREEP BUTTON
•TRANSBRAKE HOLD BUTTON
•TRANSMISSION DOWN SHIFT
•TRANSMISSION MODE SWITCH
•TRANSMISSION NEUTRAL SWITCH
•TRANSMISSION REVERSE SWITCH
•TRANSMISSION UP SHIFT
•TRIGGER CAM/HOME
•TRIGGER, HOME+CAM DUAL SENSOR, CAM SENSOR
•TRIGGER, TRIGGER SENSOR
•TURBO SPEED SENSOR
•USER CUT TABLE X, ENABLE
•USER PID ENABLE CONTROL
•VEHICLE SPEED SENSOR VSS (SIMPLE)
•VIRTUAL FUEL TANK DECREASE
•VIRTUAL FUEL TANK INCREASE
•VIRTUAL FUEL TANK RESET LEVEL
•VVT CAM POS. EXHAUST/INTAKE
•WHEEL SETUP (USE SETUP 2 WHEN ACTIVE)
•WATER/METHANOL INJECTION, LOW-LEVEL SENSOR
Note: All digital inputs can be triggered using a Digital input (DINx), or by using the internal outputs.
