Good info Exidous, thanks.
I've got a cruise box from a '98 Camaro, which is same year as my ECU, so wiring should be pretty easy. The box is surprisingly big and the cable from it is a fixed length, so doing a clean looking installation will be a bit of a challenge. Would rather keep it in the engine compartment, as I truly hate working under the dash.
Kinger, where did you mount your cruise box?
