March 29, 2025, 04:53:52 AM
Author Topic: Dark Phoenix Trans Am: LSX Twin Turbo  (Read 3294 times)
Offline bstallion
« on: December 27, 2023, 09:38:54 PM »
Thread Intro:
Not an RX-7, but LS and Turbo.
This build has no real purpose.
The only goal is that it starts, runs, drives, and stops.
This has been the journey so far..
Been having a 1981 Trans Am for a few years now. It was built for Autocross and that’s what I used it for. There were a few times I wanted to trade it for a swapped FD, but I kept it. This one originally came with a 4.9 (301) Turbo. It had already been swapped to a 406 sbc and M22 Muncie 4 speed by the time I got it.
Day One and On:
Right from the start, I gave the car some nice additions.. headlights, black carpet, stereo and speakers, POR-15, Kilmat, better seats, 5th gen console, RX-8 shift knob, Speedhut Gauges.
https://youtu.be/j_cXBkoGy6Q?si=ctYOlrcF67mRx8_3
https://youtu.be/TVPWWrmEUZs?si=l9RBeUalWERgTGu9
https://youtu.be/WWLzmkT0yME?si=-V1vOxumSHSGRL3t
https://youtu.be/F7r510qNVu0?si=3bWmcBUD_cbxzgWj
https://youtu.be/hKlCQ6AWzow?si=wEY12IDEEQncPPxJ
I took the car to the occasional car show and tinkered around with it here and there.
I left the car alone for a long time. For almost the whole past year it laid dormant, doing nothing.
T56 Transmission:
Earlier this year, I picked up two T56 Transmissions and an LS1 in the same weekend. The LS1/T56 is for an FD I got earlier this year (I’ll make a build thread on that later). The other T56 was planned for my other FD or another swap project.
https://youtu.be/Nw4JWW8hc-Y?si=MYu-W_g2lg75JuHs
Turbo Kit:
Not long after, I came across a good deal on Facebook Marketplace for an STS Rear Mount Turbo Kit for a 4th gen F-Body. To me it didn’t matter that it was for a specific body, I know pieces can be fabricated to fit other applications. I pulled the trigger and bought it. The S70 that came with the kit needed a rebuild, so a new GT45 was included. The new turbo only had idle time on it. The kit was a bit dirty. It didn’t take much effort to get it clean. When I got it, I didn’t know what some of the parts were, like the oil scavenge pump, now I have a little more knowledge on the system works.
https://youtu.be/ieK7Jl1tgp0?si=BYSp7lmnWyqTdMPZ
Resurrected the Car:
I was thinking hard about getting a C4 Corvette to drive around, as my FD swap might still be a little while. Then I thought, just use a car I already have. That, and the Crusin’ the Coast car show was coming around and an old Trans Am is the best fit that I have to take to such a show. After a year of sitting under a cover and doing nothing, I got the car to start. It was rough all over. I thought the carburetor may even need a rebuild.
https://youtu.be/_rQPjFYotzc?si=Ns2IPTNkpr-mls1e
Slightly Better:
The week leading to the show, I cleaned the car up a little and was getting the lights wired up (I started rewiring the car sometime before I parked it and never finished). I changed the carburetor out and all the other needed was a plug on the vacuum port, but this was a better unit anyways. For some future fixing up, I bought a new bird decal for the hood and a dash pad to put on the dash.
Around Cruisin’ the Coast, a buddy and I had tossed around the idea of 6.0 swapping it and giving it two turbos. I already planned to 6.0 swap it, the turbos sounded even better. At the time, I had a new hood and he primed it just before the show. I put some fresh spark plugs in and we got the carburetor tuned. I drove it briefly before bottoming out and the exhaust was dragging after the mufflers. So I parked it and dreamed about an LS/T56 swapped Trans Am.
https://youtu.be/hVSJyvPu7I4?si=lodVisqbdkZ9He44
Above was some catch up..
The New Build starts here..
L96 (Gen IV 6.0 Engine:
I had a 2500HD Silverado purchase in the works for a while. This would be the 6.0 engine that I planned to put in the Trans Am. From what I can tell, the L96 is the best LS/Vortec engine to put turbos on. At first, it sounded/looked like it was just a head gasket. With a jump, the truck did start and move under its own power. We got the truck moved and engine pulled. He had partially torn the engine down just to see if it was worth rebuilding. It was good!
https://youtu.be/gRAFNfrIVqs?si=CGKBPzwPK0hV-zm_
Engine Rebuild Parts:
I put an order in for rebuild parts, parts to freshen the engine up, and parts to start the swap.
Rebuild Parts:
Truck Norris Cam Kit  (BTR)
Michigan Motorsports LS7 Lifters (97400)
Michigan Motorsports LS7 Trays (97500)
Michigan Timing Chain Kit (12586481)
Cam Bearings (25-CC433) (CH-33)
Main Bearings (248-5M7298H-STD)
Rod Bearings (248-8B663H-STD)
Head Bolts (25-TSPHB0568-KIT)
Head Gaskets (12589227-02)
Piston Rings (2M5170)
Rear Main Seals (BS40640)
Timing Chain Cover (555-50322)
Melling Oil Pump (M-295)
Everything new going into the engine. I think refreshed and Cammed alone would be a huge upgrade from the current set up. Even if some of these parts were still ok, it made sense to get a new timing chain and oil pump, this engine had 260k miles.
Swap/Turbo Parts:
Trans Dapt Engine Swap Mounts (969-4203)
Swap Plates (Adjustable)
Holley Terminator X (550-905)
Holley Fuel Pump (HY-Fuel)
-6an Fuel Hoses/Fittings (KT01486BK)
F-Body LS1 Oil Pan (RC31130004)
Oil Pick Up Tube (12558251)
Holley 100 lb Injectors (552-108x)
DBW/Gas Pedal Kit (Pro Touring Store)
Power Steering Adapter (DD-LS-PSF1)
Oil Pressure Sensor (926-040)
Fuel Fitting -6an w/ 1/8 NPT (Breezliy)
Fuel Pressure Sensor (7990150)
Spark Plugs (NGK 3346)
Intake Air Temperature Sensor (213-190)
McLeod Clutch Kit (6405507)
McLeod Hydraulic Clutch Kit (1434005QD)
Pilot Bearing (690-057)
T56 Mount (3.1108G)
Magnum Shifter
SAE 30 Lucas Break In Oil (10631)
Transmission Fluid (Ams Oil ATF)
GT45 Turbo (ZY80097341)
Turbo Headers (Speed Engineering)
Turbo Blankets (CALU LUKY)
3” V-Band Clamps
T4 Flange (27103-1)
AEM Wideband Gauge (30-0300)
AEM Boost Gauge (30-4406)
Billet Hood Hinges (CFN Products)
Eddie Motorsports Trunk Strut Kit (MS148-07P)
E-Brake Kit (555-630583)
Braum Seat Belts
American Flag Steering Wheel (Cleetus)
Misc. Brackets
Misc. Hardware
Misc. Fluids
Misc. -an Fittings/Connectors
Wouldn’t need a big swap kit because I figured headers would go to waste and could probably get away with the same transmission crossmember, so I got just the engine mounts/brackets kit. I also had some swap plates that can push the engine back that was on the LS1 I bought, it came out of a 70s Camaro. Terminator X was the ECU/Wiring of choice for a turbo build, this was a pricey piece. Didn’t need the Max because of manual transmission. Holley also had a drop in fuel pump with built in regulator. For new fuel lines, I got a -6an 25’ hose and fittings kit. Most car swaps need a 4th gen LS1 style pan for the sump and clearance, got that. I knew the pan swap would need a pick up tube to match. Injectors would need to be upgraded, I looked at Deka 80s for while then ended up getting Holley 100lbs that work for EV6 style. The throttle body that comes on the engine is a DBW style, I tried to plan ahead and got a conversion kit for the car, i figured using everything we can from the donor would be the best cost effective options. In this case not buy a new throttle body and cable. Dirty Dingo and other companies make a fitting to keep power steering from old rack to new pump, I picked up one of those. I ordered an oil pressure sensor, intake air temperature sensor, fuel pressure sensor (and fitting to go with it) that work directly with the Terminator. From research, it seems that BR7s were the plugs to go with, the NGK 3346 are supposed to be the same thing. I needed a clutch that can hold some power, a McLeod RST is what I got, another pricey piece. The Muncie was an old linkage style transmission, I am going hydraulic style, needed a kit for that so ordered one specifically for the second gen. The engine didn’t have a pilot bearing so had to get that. Got a new mount for the T56, could’ve used the old one that was on. Sold off the shifter thinking I was putting the transmission in the other RX-7 with an MGW, so had to get another one. Got plenty of oil and transmission fluid for breaking in.  Already had a GT45 so just needed to get another one. Turbo headers is need of course, got blankets, v-bands, and another T4 flange. Wideband and boost gauges seemed like a must. I want to be able to pop the hood and trunk with ease, which is why I got the new hinge kits. The takana seat belts suck so got new Braun belts. The American Flag Steering Wheel, that speaks for itself.
https://youtu.be/X19-vyCpAMQ?si=MXLF8mtisowR0off
Engine Rebuild:
We finished the tear down together. From here, we were able to see that a loose cam bearing was the problem the whole time, good thing they were all being replaced anyways. All new bearings went in, the Truck Norris Cam was installed, pistons cleaned and put back in with new gapped rings, new timing chain set and oil pump went on. The heads disassembled, ported, and rebuilt. We were able to rebuild the engine within a day. The new oil pick up tube didn’t come in yet so we didn’t get the F-Body pan on. We put the turbo headers on just to start getting some ideas.
This was my first involvement in an engine rebuild. I learned a lot from it.
The rebuild parts are all things new that went into the engine. Other materials needed was a rotary tool and bits for porting. Diesel, picks, scotch bright, sand paper, and parts cleaner for cleaning. Assembly lube, oil, and transmission fluid for lubrication. Cam bearing tool to get the old bearings out and install new ones. Ring gapping tool for gapping rings (much quicker and easier than using a file). Spring compressor tool to remove old springs and install new ones in the heads. Regular tools and torque wrenches for disassembly and reassembly.
https://youtu.be/U7oS77szlWg?si=WWGOg0FyVWeUkbWg
Pulled 406/Muncie:
The engine (406)/Muncie pull started at the same time that the L96 was being put back together. Towards the end of getting the engine (L96) back together, we divided and conquered. He finished on the engine (L96) while I started disconnecting the 406 that was in the car.
https://youtu.be/sqag1Sg0j2E?si=cilbqMp87xMTmlfY
More Parts:
After each time we make some progress, we can see what parts need to be ordered to continue. When the 406 was pulled, I knew I didn’t want to use the old bulky clapped out radiator that was in. I had already ordered an emergency brake kit. When getting the engine back together, I learned that when swapping to an F-Body oil pan, that not only the F-Body pick up tube is needed, but also the windage tray. I broke the pan trying to get it to fit so I needed to order a new one. The turbo kit that I picked up just to have didn’t have a BOV and only had one Wastegate. So that created me part of another list.
4th Gen Radiator (BYOT)
4th Gen Fans (BYOT)
4th Gen E-Brake Handle (BYOT)
Truck Throttle Cable (Pull-A-Part)
Valve Cover Gaskets (VS50504R-1)
Oil Dipstick (921-009)
Oil Dipstick Tube (921-003)
F-Body LS1 Windage Tray (12558253)
Fuel Filter (FF4508DL)
Fuel Filter Fitting (800-170)
Tick Slave Cylinder (U24264182)
T56 Reverse Light Harness (100228)
T56 Reverse Lockout Module (555-82513)
CarBole 2”x50’ Heat Wrap
3”x4” Flex Pipe (HM1035)
3” Intercooler Piping Kit (FBA MS-78880)
T4 Flange to 3” V-Band Elbows
3.5” V-Bands (EV01353S3.5-2)
50mm Wastegates (SUM-260074)
50mm BOV (SUM-260070)
Oil Return Fitting/Bungs (BEFBA002053-1)
ICT Billet Pan Sensor Plug (551413)
1.5” Stainless 90s (Upper Hose) (SUM-622149)
I knew I wanted a nicer radiator set up, and the 4th gen are good for the LS1. I do want a hand brake so pulled one from a 4th gen. I am seeing that no one uses a DBW with the Terminator, only with the Max, so I picked up a throttle cable off a truck while I was wandering the Pull-A-Part. I was cleaning off some valve covers so got some new gaskets for them. Oil dipstick and tube for the LS1 style pan. Had to get a new pan, and this time got a matching (working) windage tray. Since the fuel pump has a regulator, I could use a regular inline filter and have a returnless system, I opted to used a 4th gen set up. Got a slave cylinder and remote bleeder from Tick. The Terminator doesn’t connect to the transmission because it’s not a Max, so I got a reverse light pigtail and lockout module to wire up. More for the turbo, I have some heat wrap, flex pipe in case it can go anywhere, universal piping kit for Intercooler, T4 to 3” V-Band since my other flanges didn’t work, new wastegates and BOV. For the oil return, we planned to tap the pan with a bung/nut fitting. Got a plug for the oil sensor in the pan. Ordered two 1.5” stainless steel 90s for something (was thinking the wastegates).
https://youtu.be/YK6hU_wrW2M?si=XJWPnEQfciCGmdYB
Engine/Transmission Mock Up:
Now that the correct windage tray was in and a new pan again, we got to get this on and also put on the front and rear covers. We mocked up the clutch then took it back off. We put the transmission on just to get it and the engine in the car for test fitting and mock ups. This allowed us to see what kind of turbo parts I needed to order, and what parts I already had that I can use. I thinkered around with the front and he built a new bar to run across out of square tubing.
*** From this point on, the project is a “learn as we go” build. I can’t find much source material on an LS Swapped Twin Turbo Second Gen F-Body. Some things/parts can be planned, but others might work better, so something can change on the spot. I’m open to suggestions and ideas.
It’s looking like this car won’t see less than 750hp on low boost. That will put the transmission and clutch at its max capacity, the rear end should be fine. So, this car will be held back from the 4 digits until I can get the RXT clutch or a Monster Triple disc and rebuild the T56 with a stage 3 kit, at least.
https://youtu.be/kAnotO_V3xA?si=Biwg_kYSnX6KmxBt
Fuel Pump/Radiator:
Had some more parts come in on this round too.
Fi-Tech Intake Manifold (70065)
Fi-Tech Fuel Rails
102mm Throttle Body
Hose Barb -10an (555-110597)
Griffin Radiator (1-25182-X)
Radiator Fan Shroud (20296)
Electric Fan (AV-1114)
NICECNC Alternator/PS Bracket (Relocate) (9113B00401)
CX Racing 3.5” to 3” Stainless 90 Bends (EB350R300-90-CAST-SS)
-10an Hose/Fittings Kit (Oil Return) (BRIFITOR)
3” SS Pipe 60 Bends (MBS300-600)
Heim Joints (A21122300UX0375)
The hood was far from clearing because of the truck intake manifold and alternator. I wanted to source an LS3 manifold locally but no one had a unit to sell, so I got a low profile Fi-Tech that came with fuel rails. A 102mm throttle body also came in and paired well with it. I have serval AEM Widebands, but I couldn’t find two that matches, so got another one of the same part number that I already had with the car, one gauge per side. We were thinking of remote mounting the power steering reservoir so a -10/barb fitting would’ve work for this. During some mock up, with the location of the turbos and clearance needed for the planned exhaust, the 4th gen radiator set up wasn’t going to work. So I did some research and looking around to find a 22” Griffin 3 Row, a shroud that might work for the radiator, and a fan that might work for the shroud. In order to reduce some bulkiness and move the idler pulley, aftermarket brackets for the alternator/power steering was needed. For the turbos, some 3.5” to 3” stainless 90s, -10an hose/fitting kits for oil return, 3” stainless 60s for exhaust, and heim joints for support.
I couldn’t wait to sit the intake manifold on top of the engine. While the ground wasn’t wet, it looked good to get behind the car and drop the fuel tank. We got the new pump in and fuel hose ran to the fuel rails. I’m liking the -an hoses and fittings, might have to convert everything I can over with them. After the fuel system, we moved towards the cooling system. He had a good idea to use isolators that work on the bottom of the shroud, and breather bolts with wing nuts that work on the top of the shroud. Worked perfectly.
https://youtu.be/gBs7b7Om0xY?si=Xw3xaNNTcbRmSPwT
On a side quest, I got to get my cradle welded into the rear subframe for my 8.8 swap on my FD.
Even More Parts:
This wave of parts wasn’t too bad, a lot of small parts. Some have been on back order and just getting in.
Fuel Gauge (CY032)
BOV Flange
NICECNC Alternator/PS Bracket (Stock) (9211119301)
Intercooler (REV9 Type 1)
Holley Bulkhead (MOTOQUEEN)
Breathers (3991)
Eagle Scream Horn (7295879919062)
-6an Caps (AT592906ERL)
-6an 90 (Evil Energy CS00111SANG-1)
Oil Feed and Fittings Kit (MSCRP)
Heim Joints (POS12)
Heim Joints (GSK-7)
3” SS Pipe 30 Bends (MS300-30)
3” Turndowns (555-30643)
Holley Can to USB (558-443)
4’ Throttle Cable (555-157022)
Throttle Cable Bracket (LX60101)
ICT Billet Timing Chain Cover (-10an 551595)
Billet Radiator Cap (smooth-rad-cap)
Breather Wing Nuts (41065)
Honeycomb Mesh Grill (LFW020601SV)
Just to have, I got a fuel gauge that can attach in the rails. I found a pipe of intake/intercooler pipe that has a universal flange for the BOV. The other set of alternator/ps brackets relocated the alternator to the right and hit the turbo header, so I got a stock location set. An intercooler designed for twin turbo will be better than the one I got with my kit so I got a different one. I found a firewall/bulkhead connection to run the Holley harness through, grommets would have worked fine too. Picked up a couple of small breathers for the catch can and valve cover, I used the one I have on the can for the fuel tank (robbed Peter to pay Paul, but Peter wanted to be paid back). Just for S&Gs, I got an extra horn I can wire in that will make an Eagle Scream. To complete the fuel rails, I got some -6an caps and a 90. Got some oil feed kits and more heim joints for the turbos. Got more 60s, some 30s, and turn downs for the exhaust we were planning. Wanted to have a computer connection for the Holley when the time comes. Got a universal throttle cable, the truck cable wasn’t long enough. To hold the cable, I got a bracket that sandwiches between the throttle body and intake manifold. Instead of tapping the oil pan, I got a timing cover with fittings, we’ll see if that works. The radiator didn’t come with a cap so got a new billet cap. Also for the radiator, got the rest for the wing nuts to hold the top to the brackets we made.
https://youtu.be/8JpZsCIrLlc?si=xI39QQcRFk7eMH1P
Intercooler/Oil Feed:
He got a Supra! So happy for this man to get an MK3, the build on that would be awesome. The new accessories bracket works, though it keeps the alternator sitting high and had to use a different power steering pump, but was still one from a truck. I had to run to the store to get some supplies and he had it installed while I was gone. By using a part from the truck throttle cable and the universal cable, I also got that hooked up. I had some flat aluminum bar that we used to make some brackets to hold the top of the radiator/shroud in place. I decided to use some 1.5” stainless 90s for the upper radiator hose. We found a location that the intercooler can fit in place. He also welded brackets to mount it to. We ran the turbo oil feed lines. I dropped the valve covers and time chain cover off at a power coater so we couldn’t route the oil return lines.
At this point, we are planning on making a cowl for the hood, I have an old one that can be used for sheet metal. Also with this in plan, the exhaust can just bullhorn out the hood. I took the turbo compressor housings to the same power coater, hopefully they get done quickly to get back on the car. I ordered a bead roller, and it is awesome! It worked on stainless steel.
https://youtu.be/RGD-yeWNzi4?si=PymQ5cDTrj_aCGTE
YouTube.com/@unleashedxauto
instagram.com/unleashedxauto
Re: Dark Phoenix Trans Am: LSX Twin Turbo
« Reply #1 on: December 27, 2023, 09:45:23 PM »
Whenever I go to car shows I rarely meet people who truly appreciate a ground up build. Very nice to see fellow nut jobs getting at it.
« Reply #2 on: December 28, 2023, 11:03:32 AM »
Way cool.   That's quite a project!
Offline bstallion
« Reply #3 on: December 28, 2023, 01:20:52 PM »
We exist, haha.
It’s a learning experience.
Offline bstallion
« Reply #4 on: December 29, 2023, 06:45:45 PM »
Even More Parts, Again:
More parts that were ordered/came in. Most of it is for the turbo/Intercooler/intake part of the project, piping, couplers, and reducers.
Holley Screen Mount (Etsy)
Holley Terminator X Mount (CarChains3D)
5th Gen E-Brake Handle (BYOT)
LED Signal Lights (KaTur)
Transmission Crossmember (6519)
Exhaust Flanges (555-31950)
Turbo Feed Fitting 90 (555-100891)
Shaker Weatherstripping (691-10012875)
Air Temp Sensor Bung (GS-FA-Bung-38)
1.75” SS Pipe (Lower Hose) (Verocious)
G-Plus 19 Row Oil Cooler Kit (A-02EGZ0006TBK)
ICT Spark Plug Wires (551083)
ICT Remote Coil Pack Brackets (551583)
1.5” Coupler (90) (MMCP-1590BK)
1.5” Coupler (Straight) (MMCP-1.5HPRD)
1.75” Couplers (90) (MMCP-17590RD)
1.75” Coupler (Straight) (MMCP-175SRD)
3” to 2.5” Reducer 90 Bend
3” to 2.5” Reducer
3.5” to 3” Reducer (TMKOOL)
4” to 3.5” 90 Reducer (HEAAEH RACING)
Heater Hose Bypass (626-01)
Over Flow Tank (EV00481SR-CA)
4” to 3” Reducer (HiwowSport)
3.5” Aluminum Pipe (216010)
ICT Coil Base Plates (551115-01)
Silicone High Pressure Vacuum Hose (Evil Energy)
Map Sensor Adaptor (558-416)
Powersteering Reservoir (603-850)
A mount for the Holley screen seemed convenient, I got one that can tuck away. Also got a mount for the Terminator rather than bolted it directly. Found a 5th gen in a junkyard, I wanted the hood, but got the e-brake handle to better match my console. Got some LED Lights to retrofit as some turn signals. The old transmission crossmember wasn’t going to work so got the same one that was make for the engine mounts I had. Got some exhaust flanges in case we do a hood exit. Another turbo feed 90 to fit the oil feed under the intake manifold. A new shaker seal, I want to keep the shaker in position when the hood opens. Got a bung for the intake air temperature sensor, will have to get it welded once we see where to put it. I liked the stainless upper radiator hose so much, I ordered some to make the lower. Got an oil cooler kit, if it doesn’t dot the job, I’ll get a fan for it. The coil packs don’t fit because of the turbo headers, so got longer plug wires, a relocation bracket kit, and coil base plates. I got coupler for the upper and radiator hoses. I got couplers and reducers for the intercooler/intake. Got a heater bypass hose. Going with a new overflow tank, the one I was using looked janky. For the air filters, I got a piece of 3.5” aluminum pipe to cut down and bead roll.
Randomly Planning:
While waiting on the Compressor Housings, Timing Chain Cover, and Valve Covers from the powder coater, we worked around those areas. He worked toward exhaust welding and I started looking at the transmission crossmember. My car happens to have some subframe connectors welded under it, so the crossmember isn’t going to work. By using some of the kit, a new one can be made.
The stainless I got for the lower hose only needed a small piece because the couplers were so big. The bead roller I got was able to roll that too, this is thicker than the 1.5” stainless.
We got the power steering pulley on. I used a pulley puller and installer for the first time, so learned something new. We routed a long belt to reference a new belt size and got it right.
I looked at ideas on how to run the wideband gauges and the Terminator. For the most part, the Terminator wiring can only go one way, but where to mount the unit is what I was looking at. I’m thinking under the dash on the passenger side. I drilled holes for the bungs (bung holes) and he welded up a new transmission crossmember. I had to cut it short this time because of Christmas stuff.
Offline bstallion
« Reply #5 on: January 05, 2024, 07:05:10 PM »
Coil Packs, Terminator X, and Crossmember:
Parts:
Holley 2.5 Bar Map Sensor (870021)
Boost Gauge Harness (AVM-30-3405)
Fuel Fitting 45 Bend (EAR-AT991501ERL)
-8an Hose/Fitting Kit (FSBCGT)
A few more parts came in. The 2.5 bar map sensor is to upgrade the stock unit. My harness for the boost gauge de-pinned itself somehow, so a new one was cheap enough to order instead of trying to find new pins and a diagram. The new position of the fuel gauge is odd so a 45 degree fitting will make it easier to see. Some of the rubber hose look janky, to fix that, I got some -8an hose and fittings.
Bungs for the O2 Sensors were welded. We are going with a total of three. One on each side for the AEM Wideband Gauges and the one that came with the Terminator.
We cleaned up the 406 and Muncie that came out. It’s time to try and sell them. The market looks like they sell for a decent price, but limited to those who actually want them.
Took car of some minor things like putting the heater bypass hose on, rerouting the fuel connection to the rail with another 90 (have two 90s back to back, this could be a 180), new oil pressure sensor put in, and a 45 to adjust the fuel pressure gauge angle.
The next thing was to relocate the coil brackets. The OEM brackets won’t work because of the turbo headers. I took a gasket with the new bases and relocation bracket, wasn’t sure it would all work together, but it did.
 Vacuum hose run from the Wastegates and Tee off under the intake manifold, they follow the oil feed. On the driver side, the Wastegate Tees off with the BOV.
We found a good place to mount the Terminator and we made an existing hole bigger for the bulkhead flange. For a cleaner look, he put together a stainless plate on the exterior. The bulkhead flange was designed with two holes, one doesn’t need to be used because my battery is relocated. So with that other hole, I’ll route the AEM gauges through it.
With that done, most of the engine wiring is pretty much complete. We were able to plug in just about everything and now have the O2 sensors in place.
The Trans Dapt Crossmember didn’t work out like I hoped. If put in place, it would make the transmission sit too high and a lot of transmission tunnel would need to be cut/modified. This looks like the reason for that is due to some homemade subframe connectors. Instead of doing more cutting to the tunnel and frame, he made a crossmember last time we worked on the car. We used that and got it to work. The transmission is now held up, without a jack.
« Reply #6 on: January 10, 2024, 10:46:33 AM »
That's a huge amount of work done.  Wow.
Offline bstallion
« Reply #7 on: January 12, 2024, 05:41:11 PM »
Getting it in only one day a week.
A Little More Complete:
Parts:
T56 Panel (A97207)
I was able to pick up the parts from the powder coater. I had the valve covers, timing chain cover, and turbo compressor housings done in red. At first I was super excited about the parts being done. For the price and results, I was disappointed but tried to keep positive about it. The candy colors are just pricey and there was flaws on the powders coaters end which they offered to recoat the parts. I have been inspired to start coating my own parts, anything that can fit in a standard oven anyways.
The timing chain cover and compressor housings went back on the engine/car. Since the timing chain cover was back on, the turbo oil return lines were able to be ran. (This cover with fittings only work with truck and Camaro LS3 accessories spacing- or so the package said).
We put the sparkplugs in and plugged the wires to the coils to see how long to cut the wires. I had to go on a tool/parts run so he cut all of the spark plugs wire to size while I was gone. Also while I was away, he trimmed the front cross car and radiator brackets for a cleaner look.
With the compressor housings back on, the heim joints were able to be placed and installed to support the weight of the turbos. Studs were welded to the cross bar to hold one end, and the other end bolted to the housing.
He made up some brackets on the cross bar to hold the coolant overflow tank. I put some rivnuts in the brackets and used that to secure the tank to them.
On my parts run, I went get a bared fitting to tap into the water pump… and tapped it into the water pump to flow from the coolant steam vent.
We circled back to the idea of running the exhaust through the fender vents instead of bull horning out the hood.
Offline bstallion
« Reply #8 on: March 25, 2024, 09:47:09 PM »
Still been working on the car weekly, haven't been keeping up with the Build Thread though.. Some of the pictures and details may be a little out of order..
Figuring Out Exhaust and Completing Intercooler:
Parts:
2” Straight Stainless (93623)
90 Stainless Elbows (SS304-003.5-3.5000US)
2” Flex Pipes (RCCT041)
4” Air Filters (RG-1001RD)
1” Loom (sr1inblack25ft)
3/8” Vacuum Line (Ucreative)
Distribution Blocks (98MF18044)
45 Couper 3.5” to 3” (SH-45D-R-3-3.5-BK)
-8an Hose Kit (B09Y182C6N)
Oil Drain Fitting (BC05-ZH)
2" 45 Aluminum Elbow (AP45-200)
Got the rest of the material to complete the intercooler set up. Looked into using the brake master cylinder off the truck (2011 2500HD). It looks like it can be used without too much effort. Tried to wrap the exhaust headers. My side didn’t come out too good. A set of power and ground distribution blocks came in. We got those in place to start planning routes for wires. We figured the rest of the material needed to complete the exhaust. A little piece is needed for the driver side and some 90’s are needed for the wastegates.
More Exhaust Complete:
Parts:
3” Bend 180 Stainless (ZTL-PP-30-180-SS)
Exhaust Hangers (339819S)
For while we have been talking about getting an AC Tig welder. I found a decent deal on Market Place and picked one up. This should open us up to the opportunity to use aluminum  as material. Also, I’ll need a driveshaft made for my RX-7 later. This will allow one to be made. We needed to get the hydro booster off the truck installed to build the driver side exhaust around it. The cross bar on the very front needed to be trimmed a little so the air filters could fit properly. The vacuum lines are ran from the blow off valves and wastegates to the intake manifold. The driver side wastegate is now welded into the exhaust.
Engine Back Out:
We moved the car a little to get the engine and transmission pulled out.While the engine was out, we took some time to get the bay cleaned up a bit. The turbo/engine and transmission set up outside the car looked so beautiful! I would like to have a build as a display… if I had the extra money and space. While the engine was out, we made a plate to mount to the firewall for the Holley Bulkhead and distribution blocks. This plate was made out of a hood as material.
Engine Back In:
Before putting the engine back in, we cleaned the bay some more and put a coat of primer and some paint.. so it would be one color. We took the transmission off to get the clutch on for good. We followed the instructions from McLeod as neither one of us has experience with installing a clutch kit. We set the engine back in and started the reassembly. The transmission can go on later. The red valve covers are now on and they look beautiful.
Been a Long Wait:
Parts: Painless Harness (20114)
I placed an order for a new body harness from Painless back in November. The thing took 3 months to come in. I assume they are made to order and Painless was busy. I wanted one of these because it is specific to the car and a direct replacement to the original harness, which my car hasn’t had for quite some time. I had a new universal E-Z wiring harness in it just to get by. I much rather use a painless though, everything needed for the car is there.
T56 Stuff:
We started off working around completing the lines from the master cylinder and lines for the power steering. Power steering pump came off to weld a barb fitting on it so the line can slip on (hydro booster bypass). The T56 still needed the salve cylinder put in. The slave was put on and the remote bleeder line was attached. The clutch was torqued to spec before we put the T56 on the engine. The booster got to go back on and all lines were plumbed. The booster had was off one more gain so the hydraulic clutch kit plate can be sandwiched between the booster and the firewall. Because of the new style booster, the plate needed to be bored out a bit. The clutch cylinder mounts directly to the plate and the clutch line attaches to it. It comes with a reservoir that is to be remote mounted.
Traded 406 for 6.0:
I decided to put the 406 that came out of the Trans Am for sale. I got a bunch of goofy offers, but after having the engine sit in the way for some time, I took an offer that I can use. I was offered a 2007 Iron Block 6.0 and new 88mm turbo. I’m sure the 406 was worth way more, but that would have been to a very specific market. I wasn’t going to use the 406 for anything. A 6.0 I can put in one of the several projects I have. It supposedly has ~90k on it. Well, that will be put off for a later project.
Final Engine Wiring and Assembly:
Parts:
Alternator (R111970A)
Starter (R613399A)
Crank Sensor (12703627)
Alternator Connector (B07VSYK8WZ)
2-Step Module (8733)
Oil Filler Neck (12609623)
LS Oil Cap (BOKOP71)
Flex Fuel Sensor (13507128)
Flex Fuel Harness
3/8 Transmission Line (EV07122S1BK-1.5)
Brake Union Kit (MUBRAKE-NEW-FIT15)
-8AN/ 3/8 NPT Fittings (CS00272S0806)
Misc. Hardware
Moroso Spark Plug Kit (72133)
Lucas Brake-In Oil (10631)
3/8 Round SS Rod (B-.375-304LSS-K3)
Spark Plug Boot Heat Shield (A-SP-01)
Fuel Filter (FF881DL)
Belt (990K6)
Belt (985K6)
Belt (K060975)
Belt (K060970)
77-78Front Nose
Getting the last bits plugged in. At this point, everything pretty much needs to be tighten and power for the Terminator ran to the battery.. to get it started. However, I did remove the body harness which had the dash and ignition switch wiring with it. The new Painless Wiring body harness just happened to come in after a long back order.
The fuse box would be better mounted where the kick panel is instead of the firewall. It won’t fit right in the stock location because of the brake booster. We took a gromet off of the donor truck and cut a new hole for the harness to pass through into the engine bay. We made an adaptor plate to mount the fuse box to so it can mount in the side in the driver foot well. So, the ignition switch, battery, starter, and alternator was wired. The alternator looks clapped out so I got a new one for a 4th gen F-Body. The starter was weak. I got it tested and it was bad. A new starter was put in and some stronger grounds.
The First Start:
The Holley wasn't lighting up all green. We found what all 8 LEDs are supposed to be. 6 and 7 (crank sensor and cam sensor), were blue. We got them green after replacing the crank sensor. I did purchase a new crank sensor from the dealership but they gave me a black one (24x). At the time, I didn't know it had to be grey (58x) for a GEN IV. So, all lights were green but the fuel pressure wasn't high enough. We plugged off the regulator in the tank and reconfigured the fuel system a little by added a Corvette filter/regulator. This was a solution. The engine turned over and started! So exciting! It runs! It started, but it didn't sound 100%. It seems the driver side isn't firing, so only half the engine is firing. The Holley is blue again for the crank sensor. I'll get another new one (58x) and a new MAP sensor and see if that fixes the problem.
Offline bstallion
« Reply #9 on: July 24, 2024, 08:37:06 PM »
LRB Aluminum Door Panels:
My door panels were beyond my ability to restore, and this isn't a car that needs factory panels.. so, I got some LRB Aluminum Panels.
I've used these in two of my FDs and in my SC400, that gave me plenty of experience in working with them.
I was surprised to see they were available for this car.
Driveshaft Made:
About time for some more Trans Am action. The Holley ECU keeps showing indecisive colors for the Crank and Cam Sensors. They start off all green, then go to red when cranking, and then back to blue. Green is good, Blue is a gap, and Red is an error. It can't be that these sensors have all three. The sensors are new and the crank sensor has been replaced several times. Could be that there is a malfunction with the ECU so we will send it off to get tested. In the mean time. I pulled a driveshaft from a Silverado in the junkyard, I read that the 4L60 using the same yoke as a T56. The muncie also used the same yoke. We made two driveshafts and went with the bigger one. We reconfigured the charge pipes for the intercooler. This will save time on building a cowl hood. The brake lines were also finished. As a bonus, we took some of my left over turbo stuff and put it on a 2500HD.
'77-78 Front Nose TRANSformation Started:
Sometime while waiting on the ECU to come back in, I decided I wanted to pull the trigger and get the '77-'78 front nose.
It's been a long time coming. Since I got the car years ago I've always wanted to put the '77-78 Nose on it. Now, I started the process.
I assumed just the bumper needed to be replaced, and then get the required bezels around the headlight. I found out that it is not possible to convert without the '77-'78 headlight panel. To get a headlight panel for the best price, I needed to order another bumper that comes with one, then I ordered the bezels separately.
Running Better:
The ECU finally came back from Holley and it passed the testing.
We thought after several new crank and cam sensors that the ECU may have had a malfunction.
When the crank and cam sensors did read, the rpm still had a stall.
Our goal was to have it turnkey for Cruisin the Coast this year in Biloxi.
We were hoping to at least go debut it at Scrapin' the Coast because we got it to run.
We figured we could start it up just to show others but once we put the transmission back on it stayed stuck.
The Holley still showed a stall anyways so it would have been a little premature to try and showcase the car.
Turns out that the Holley harness had loose connections on the plugs.
Now the car runs on all 8 cylinders, has no gap in the crank or cam sensors, and also has rpm.
Like I said, sadly, the T56 is stuck in gear (or won't leave from the position its in).
Pulled the transmission, opened it up, and it is dirty, like water would have gotten inside.
I ordered a stage 2 upgrade kit before taking the transmission apart and turns out it needs more than that.
I'll take it to a local Transmission Shop and then use this one for one of my FD builds.
« Reply #10 on: July 25, 2024, 11:26:40 PM »
That’s a ton more work.  Glad you sorted the Holley issue!
Offline bstallion
« Reply #11 on: January 13, 2025, 08:15:40 PM »
Moves Under Its Own Power:
Last time we got all the engine wiring sorted out and it runs good. We had some transmission problems, it was stuck in neutral and looks like it went under water. Luckily, I had another T56 on hand. We put the replacement in and found out we was short a clutch line when we went to bleed it. We got the line in and realized we needed a shim for the slave cylinder. All that was now taken care of with the transmission back in the car with the assistance of the car lift. After all that, the car went into gear and was able to move on its own!
Custom Shift Knob:
The Shift Knob is from Speed Dawg Shift Knobs. It has a momentary button/switch for the 2 Step, which I discovered Holley has it built in.
Getting Ready for the Road:
Knocking off the to do list to get the car on the road soon. We took the car to a tuner to get some recommendations on what to do before bringing the car in for a tune. We raised the turbos higher for better return for the oil. The oil catch can was updated and some -10an fittings were welded to the valve covers to route to the oil catch can. More vacuum lines are ran from the waste gates to reference the intake manifold and we now have a mac valve installed so the Holley Terminator can control the boost.
Wrapping the Build Up.. For Now..
https://youtube.com/shorts/TeEl1FvDarc?si=sTGg1S-RtjulP6qB
Its been a very productive year working on this car. We’ve accomplished and learned so much. Last year for Cruisin the Coast, we had the idea to do a swap and twin turbo it. I had a truck I was already planning on buying that had an L96 and had a GT45 laying around anyways.
We was able to take the car to a local tuner and get a tune so the car can drive on it. In the shop, I was fan boying on all the nice builds.
I tune was uploaded on the Holley to take it for a drive.. and then, the car got to go on the dyno.
This is my first car that ever got put on a dyno.
So.. this test pull was full send. I got a mac valve to use as a boost controller with the Holley Terminator. I referenced the vacuum lines wrong and the waste gates never opened.
So it did about 21 lbs of boost, we are guessing that’s probably in the 1000 hp area, but the tuner wasn’t logging.
Then the tuner did a real pull while logging. This tune is just to make the car drivable. It made 442 with no boost. The fuel was almost maxed out, it would need a better fuel pump or a second pump.
Later, we were able to safely take the car out on the road for the first time, it was so fun. It was time to replace the busted windshield with a new one. With a  fresh windshield, I took the car out on the interstate and drove it to the coast.
We just wanted to see if we could do it and we did. We tossed the idea of making it a drift car, I think the RX-8 would be better suited for that. Now that we completed this crazy build, it needs a more practical purpose. I don’t have what it would need to support anything over 800 rwhp anyhow. The clutch is rated for 800, the T56 can maybe hold 700 – 800, the fuel pump probably maxes out around 550 to the engine, the 10 bolt rear end, I don’t know, 450-550, correct me if I’m wrong. There is no point in having two GT45s on a 6 liter in this car on its current set up. I started thinking realistically and considering everything I and we have to work on. It would be so nice to have a four link, 12 bolt rear end, coilovers on this monster, but those conversions are at least another $5k and I’m now one of those broke people. I’m not sipping faucet water and eating ramon noodles broke, but still pretty bad. I’m rich in LS engines and project cars though. I’m not sure when it will return but when it does, we will be putting a 5.3 with a single turbo and going to do the body work, paint and completing the interior.. I already have another engine, I will need another transmission because my FD needs the T-56 I used for this car back..
« Reply #12 on: January 14, 2025, 11:14:21 AM »
Congrats on the progress and actually getting to drive it.
FWIW, I've got a few friends putting >1000 WHP through a T56 (or TR6060) but you definitely need to be nice to it, tire wise.
