March 18, 2025, 06:15:41 AM
Author Topic: LS7 427 LS Comp Cams/RHS Shaft Mount Rocker System 1.8:1  (Read 1041 times)
Offline R_1
« on: October 09, 2023, 09:09:45 AM »
Using Comp Cams/RHS Shaft Mount Rocker Systems is one of the most effective ways to increase horsepower. These systems transfer the power of the camshaft to the valve by properly positioning the rocker over the valve. Constructed from 2024 aluminum and using an 8620 hardened steel shaft.  Shaft rockers are designed using the latest in computer technology and are field tested by experts in every type of racing.
Made from 2024 aluminum and use 8620 hardened steel shaft
Most efficient way to transfer the power of the cam to the valve
Rigidity of the shaft system adds stability to the cylinder head and the valve train
Uses an oiling system that ensures consistent oil flow from the pushrod cup to the shaft bearings and then on to the roller tip
*Requires valve cover spacer, baffle removal, or aftermarket valve covers.
NEW IN BOX $1200.00
« Last Edit: October 09, 2023, 09:32:27 AM by R_1 »
Offline R_1
Re: LS7 427 LS Comp Cams/RHS Shaft Mount Rocker System 1.8:1
« Reply #1 on: October 16, 2023, 07:05:04 AM »
Offers
Offline R_1
« Reply #2 on: October 19, 2023, 07:41:53 AM »
Still for sale...
Offline R_1
« Reply #3 on: October 31, 2023, 02:01:26 PM »
Still for sale...
Offline R_1
« Reply #4 on: November 07, 2023, 02:43:54 PM »
SOLD, SOLD, SOLD
