I’m running a LS6 with a 04 GTO Alternator (AC Delco part no 92058857 & Mitsubishi Part no A003TA7991), but I have had it failed three times now and want to sense check why its failing. It’s a two wire alternator, wired up as per the 04 GTO diagram, that also aligns with the RX7 wiring diagram. I’ve even checked the lamps in the dash, I have a filament lamp on the alternator/charge indicator but a LED on the low oil light.
The first two times it failed I rebuilt it, once with a new regulator & diode pack and the other with a new regulator. It failed for the 3rd time this weekend, it started with a whining noise from the front of the car that changed with the revs, then the alternator/ charge light came on. I've stripped the alternator down and there's no obvious signs of failure or overheating.
From my searches this alternator will work with the RX7 wiring and was part of the reason I got this alternator. The only things I can think of is that the RX7 wiring has 3 lamps in parallel, the alternator charge lamp, the low oil light and the low coolant light, and with me running the low oil light with an LED, this changed the volt drop across it and increased the voltage that the L terminal on the alternator saw, but I’m not fully convinced about this.
My options now are:
1. Rebuild this alternator with new rectifier & regulator, plus change all of the dash back to lamps.
2. Buy a new 04 GTO alternator.
3. Buy a F-body alternator and wire it to the 411 PCM with resistor, but this is a ~100A alternator instead of the GTO 140A rating.
4. Buy F-Body alternator & modify with self-exciting regulator?
Has anyone had these issue with the 04 GTO alternator before, what was cause and did you find a solution?
Or are there other options I haven’t considered above?
