Ended up buying an Ionic LiFePo4 starting battery. Listed as for a boat or UTV, but only $250 for a 30 amp hour battery, vice $5-600 for the automotive ones. Comes with battery monitor and restart capability if it drains. Also has Bluetooth so you can monitor battery on your phone. 9 lbs vice 45, and fits in the rear bin much more easily.
Starts the engine much more quickly than the optima. Started 4 times in quick succession, ran the blower on max and headlights on with the engine off, and then drove for about 20 minutes to check charge rate and cutoff (took 7 minutes to get to full after being at 92 from the starts/fan). So far I’m impressed. I’ll update if it goes Samsung Note 7 on me.
