« Reply #78 on: May 18, 2024, 09:30:39 AM »
Stock ECU will usually throw a code if the crank and cam aren't syncing properly.
You said you got one good pull. Check your valve springs again. Is this still the old 383? 7500 is a lot of RPM. Anything above 6k needs careful consideration of valvetrain stability. Over 7k orders of magnitude more so. That engine was very far from optimized iirc. Wrong cam, wrong heads.
Rev limit is set there but I never get close. One pull meaning it went to 6300 and I let off. It’s just to slow after that. I think a handful of times in its life I went to 7k but it was pointless, otherwise I shift at 6300-6500.
Correct on engine 383 not optimized. New LS7 sitting in the crate 12’ away from it [emoji848]
Logged
